Flynano - Page 3 - RC Groups
Nov 17, 2017, 06:36 AM
Tony Audsley Retired Locksmith
Lockey's Avatar
Originally Posted by scorchythebear
That looks fantastic! I knew you'd have it almost finished before I even put the lid on the Skycar. Slow down man!
Have you been in touch with the manufacturers of the full scale Flynano? They might be so impressed they send you one over
I did actually send them an email Adam .. asking if they would send my ANY details, plans etc but never heard back from them
Lockey
Nov 17, 2017, 07:17 AM
Originally Posted by Lockey
Hey nuteman .. good to see you mate and (as always) your comments and advice always welcome .. where would you say the CG is ? I am assuming around the step on the hull (fuselage) .. also what are your thoughts on the motor upthrust / downthrust
I'd put CG a few millimeters forward of the step and a couple degrees up for thrust line.
You'll have lots of prop wash over the rear wing, so trimming the elevons there will be a way to adjust for a good compromise. This exactly why many pylon mounted motor designs have a t-tail - the nose down moment of thrust is balanced with the propwash over the elevator (which provides a nose up moment).
Nov 17, 2017, 08:54 AM
Lockey's Avatar
Thanks for the advice nuteman, as always I appreciate your input and will follow your suggestions
Lockey
Nov 17, 2017, 12:33 PM
Retired CAD guy
birdofplay's Avatar
I have layed out Lockey's Flynano design on MPF, which is available in the USA.
Tony will have his plans available on his site shortly.
But, for now, I have done 1 single test cutting of the current design.
It consumes 3 and 1/2 sheets of MPF and 1/3 of a sheet or 1/8 ply 12x 18"
Since a 2mm router bit cannot reach all the way down to a Point
without removing too much material I have placed a single 2mm hole at the Vertex
for the builder to simply continue the cut with a sharp Knife.
These Holes have also been placed for reference on cutting out the Elevons
and for Bending alignments.
Nov 17, 2017, 03:56 PM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Love your work Lockey....
Nov 17, 2017, 07:24 PM
Lockey's Avatar
Cheers Duke
Bob, I am using 1.2mm cutters from Bangood .. only about $10 for 10 and they work great .. it still wont go right down to the point .. just sayin although I find that the 1.2mm cutters give nice sharp corners .. I even used these for cutting 5mm corflute .. slower speed and 2 passes
I have also added a couple of formers to hold the hatch to shape (added to plans) also have marked on the plans where the hatch is to be cut
Lockey
Nov 17, 2017, 09:31 PM
Retired CAD guy
birdofplay's Avatar
I've had issues with those on occasion.
Sometimes they "Build Up" a wad of plastic and ruin everything afterwards.
Never with 2mm and That's better than the 1/8 or 3mm that I used to use.
1.5mm is close to the 1/16" bits that I also had issues with ever so often.
Do I have those formers ? like in your mods ?
I have plenty of room to add additional small formers .
Bob
PS mail has gone to heck again with blowbacks !
Gawd I thought I'd found a remedy
Nov 18, 2017, 12:52 AM
Lockey's Avatar
Bob
Will send them to you Bob, also needs a second LR3 and RR3 wing ribs but without the lugs
Lockey
Nov 18, 2017, 02:58 AM
Lockey's Avatar
I have done a test fit of the wings to the fuselage and .. man, this thing is fricking awesome
more build pics to follow soon
Lockey
Nov 18, 2017, 07:02 AM
scorchythebear's Avatar
Fricking awesome is an understatement!
Brilliant mate
Nov 18, 2017, 08:28 AM
Retired CAD guy
birdofplay's Avatar
Wow Zow & ... Howly COW !!!
Latest post received, thanx !
Mods incorporated into Layout, thanx !
I have JUST NOW copied ALL your impressive collection of build pix
to my Phone's micro SD card,
so I have reference with me while out in the shop !
I guess it's time to start building , eh ? ! ;>}
L8r, Bob
Nov 18, 2017, 01:42 PM
Dukejet's Avatar
Wow Lockey!!!... she looks bloody beautiful!!
Very quick too
Nov 18, 2017, 03:24 PM
SebastianG.'s Avatar
Oh i hate you sir...
What a Beauty!!!
New Product FlyNano - A truly amazing recreational aircraft coming soon ! - First flight ! OzparkPilot Australia 43 Jul 05, 2012 07:56 PM
Discussion Flynano! Hope someone does an electric version Ruffin Ready Scale Kit/Scratch Built 0 May 11, 2011 11:54 AM
