Difference between a Kero plug and glow plug? - RC Groups
Nov 08, 2017, 04:03 PM
Question
Hello,
Could someone explain to me what the difference is between a Kero plug and a glow plug? They look very similar but the price difference is huge.
Also would it be possible just to use like an electronic spark ignitor to ignite the kerosene?
Tom
Nov 08, 2017, 06:47 PM
Dr Honda's Avatar
Depends on what you are looking at. For a while... there was a heavy duty igniter that a few companies were putting out. It was kind of short lived since they started to just make engine "Kero-start", and they became a built in part. It was a solid rod that would stick out of the body, and was built for turbines. A glowplug is for a glow engine with a thin platinum wire. For a glowplug to work, you have to pull out a couple of the coils to expose them.
If you have a "Gas-Start" engine... just use a glowplug. Unless you have an issue with the ECU, they last for a very long time.
Discussion Temperature difference between internal sensor and plugged in sensor nonoze Eagle Tree Systems 2 Jun 14, 2017 08:42 AM
Discussion Difference between similar sized electric and glow models super_nova 3D Flying 3 Dec 05, 2006 02:29 PM
Discussion Difference between Wankel and usual glow engines Majid Al Khafaji Engines 4 Aug 08, 2006 11:43 AM
Discussion Difference between J-plug and S-Plug (servos) Smokescreen38 Beginner Training Area (Aircraft-Electric) 1 May 03, 2006 11:11 AM
build difference between glow and electric... markmm Fuel Plane Talk 26 Dec 14, 2005 11:02 AM
