Nov 08, 2017, 03:17 AM
AR6110e no communication with DXe
Hi,
I have a DXe transmitter, from a RTF kit, Apprentice with SAFE.
I ordered an AR6110e-mini receiver, to use the same transmitter on other plane.
I powered up the receiver with bind plug, a red led is blinking fast.
I started the transmitter with BIND button pressed, and the led from receiver is blinking slow for a few seconds, and at some point is turning off.
I power off the receiver and transmitter, I remove the bind plug, I start the transmitter, then the receiver, but nothing lights anymore in the receiver, and there is no command accepted.
I tried the bind procedure few times, every time is the same.
So the receiver is not dead, and is sensing that the transmitter is in the binding mode, but it seems that the binding is not finished, or, after is finished, is not paired.
I also tried some binding with another type of receiver, not compatible with spektrum, and the receiver does not change the blinking, is not trying to bind with that.
AR6110e-mini is not compatible with DXe ?
(mini is the version without the plastic case)
Thanks for replies.
Nov 08, 2017, 06:46 AM
No bounce, No play.
davidmc36's Avatar
It appears the 6110e is DSM2 only and the DXe is DSMX only???
https://www.spektrumrc.com/Products/...dId=SPMAR6110E
https://www.spektrumrc.com/Products/...rodID=SPMR1000
Nov 08, 2017, 07:24 AM
Nov 08, 2017, 08:01 AM
AndyKunz's Avatar
And if you bought that receiver "new" - it's a fake!
Andy
Discussion TBS Colibri no communication with PC (Elite Bundle) krhagon Multirotor Drone Electronics 2 Dec 27, 2017 12:51 PM
Discussion No backorder communication gatorb8 HobbyKing 8 Feb 29, 2016 12:12 PM
Discussion No throttle with Spectrum AR6110 ejohn Power Systems 3 Jan 20, 2014 05:40 PM
Who would be interested in living in a community with no electric bills? lakedude Life, The Universe, and Politics 19 May 23, 2005 11:12 PM
