Two motors spinning at once? - RC Groups
Nov 08, 2017, 01:25 AM
Help!
Hello everyone, i recently got back from buying some cables for vtx and fpv cameras and after fitting everything together im getting a weird problem.
When i go to betaflight and spin up motors 2 both motors 2 and 3 begin to spin, same if i spin up motor 3 and both motors 2 and 3 spin together? In blheli only two escs are apearing and thats 1 and 4. Im using Spedix 30a HV - 3-6s. My flight controller is the Matek F405 OSD and I have had this issue before but with different frame,fc and pdb but the lads down at the hobby shop fixed it but i dont know how! Any help???
Nov 08, 2017, 03:54 AM
What is landing :O
Check all your soldering. Sounds like a short between motor 2 and 3.
Nov 08, 2017, 05:22 PM
Hello, it turns out that i connected the ground for cam and the ground from the esc signal on the same pad causing both motors to spin... Weird (;
Discussion Running two transmission systems at once smithj8394 FPV Equipment 6 Aug 03, 2016 04:03 PM
Help! Two broken Redox ESCs at once? kapcaniew Beginner Multirotor Drones 0 Jul 23, 2016 10:03 AM
Discussion Using two props at once on one motor??? acesshex Power Systems 3 Apr 03, 2013 11:17 AM
Anyone Flown Two Zagis At Once? Martin Hanstead Foamies (Kits) 0 Sep 06, 2002 04:44 PM
Charging two battery packs at once domlou Power Systems 10 Jan 04, 2002 05:17 AM
