Nov 07, 2017, 12:51 PM
Micro Aces Se5a dihedral
Hi,
I'm building the MA Se5a and its coming along OK but it seems that the dihedral seems to sag. When building I used the jig to set it but the wing panels are only attached by gluing to one of the double ribs. The other rib is glued to the center section. I haven't mounted the top wing yet or tightened the string braces yet. Does that help or did I miss something in the build?
Ray
Nov 07, 2017, 12:54 PM
sirpercy's Avatar
The rigging sets the dihedral, just be sure to not over do it and have both sides the same without any twist
Nov 08, 2017, 06:47 PM
Thanks Sirpercy but it seems that the rigging only adjusts the wing washout not the dihedral.
Ray
Nov 09, 2017, 04:42 AM
Crashing with style
deadbird's Avatar
Hi Ray,
There are two things to do here that really make a difference;
Firstly, when the wings are in the jig apply a thin bead of CA or aliphatic resin to the joint where the wing meets the centre section.
Allow this to dry then turn the wing over - remove the jig, apply more CA or alipahtic to the joints between the ribs and the wing sections. Allow this to dry - (I usually stand the wing on the LE to retain the dihedral at this stage).
With this glue the wings should be less likely to sag than with just UHU por.
Secondly - rigging. Tension on specific wires will help support the wings - see the image - I've indicated which ones do - both front and back of course!
Nov 09, 2017, 11:59 AM
Hi Jon,
Thanks! I'm not sure that I can do this retro actively but will give it a try. I'll try to loosen all the rigging and ant use some CA at the joint between the outer panels and center section. It would be great if you could add this tip to the wing build page.
Really like your planes!
Hope that you're doing well.
Ray
Nov 11, 2017, 03:56 PM
Single-task at best...
tim hooper's Avatar
Originally Posted by kostuk
Hi,
Ray
So it wasn't just me then!
I settled on putting a couple of spots of foam-friendly CA on the joint to hold it in station.
Incidentally, my SE5a had its maiden flight this afternoon; flew just the way it should!
Tim
Nov 11, 2017, 04:02 PM
The pin-vice has run off again
fairweatherflyer's Avatar
I left mine to set over night on this thursday evening and came down in the morning smuggly expecting them to have stuck and picked them up and got the droop! have now fixed by adding glue to the upper side of the joints. needed to be rather heavy handed on the glue and hoping droop wont return. Other than that have been really pleased with it so far.
Nov 12, 2017, 10:11 AM
speedy01's Avatar
Originally Posted by deadbird
... when the wings are in the jig apply a thin bead of CA or aliphatic resin to the joint where the wing meets the centre section.
I've had much better results with CA than with aliphatic (Deluxe Materials). The aliphatic cured somewhat flexible -- not sure if this is the case with all aliphatics or just the Deluxe Materials I am/was using.
Gene K
Nov 13, 2017, 12:27 PM
jimq26's Avatar
Here's what I've been using with great success over the years - http://www.beaconadhesives.com/cgfoam.html
A drop of foam safe c/a for immediate set is also appropriate the odd time.
Nov 13, 2017, 02:09 PM
Hi,
Thanks for the additional feedback. I loosened up the rigging and used some foam safe CA on the top wing, then tried to tighten up the rigging wires as Jon suggested. It seemed to help. I test flew the Se5 over the weekend and it flies great! I actually built this one for a friend and will build another - for me with Jon's suggestions.
Thanks MA and Jon for a great flier!
Ray
Nov 13, 2017, 02:54 PM
speedy01's Avatar
Good stuff, but we were talking in regard to ensuring that the dihedral is set at the wing center join. Foam Tac (as well as UHU por which I prefer) remains flexible ... which is not the desired effect in this case.
Gene K
Nov 14, 2017, 04:47 PM
Glad to hear it flew well. Thanks everyone for the tips on glue. I will have to get some foamsafe CA before joining the top wings. Have used uhu por for some joints and aliphatic for some. but could definitely do with a little rigidity at the joint.
Regards to all
Nov 14, 2017, 09:28 PM
Yes, it needs some kind of dihedral brace. Mine gave me a lot of trouble. Maybe I'll go back to it someday, take out all the rigging, re-glue it, and re-rig. In the meantime I've given up trying to fly it.
Nov 25, 2017, 04:54 PM
Apologies All, but could I ask something slightly off topic please.
Perhaps one of you Micro Aces could tell me what to do with my electronics please!
As per instructions I have stuck the receiver servo board down with double sided tape and am wondering if that allows me access to where I need to plug the motor wires into. There seem to be two possible plugs on the receiver board a shorter protruding surface slightly nearer the nose and a slightly larger black rectangle on the back edge of the board. Could someone advise me where I should be plugging the motor in so I don't break any pins etc?
In other words I haven't got a clue how its all supposed to plug in - I've assumed the long black and white lead from the receiver board is for the battery?
next question is what battery have people used for it and where did they put the battery?
Many thanks all
Vicky
Pics attached of motor and connector and receiver/servo board.
Nov 25, 2017, 06:02 PM
The motor plugs into the back of the board. Which way? The way that makes the prop spin the right way!
As to battery, that's a sore point with me. You're supposed to put it on top of everything with part of the battery slotting into the front of the top part of the "radiator" where you should see a place for it. Then the cowl is supposed to stay in place with the little magnets. I had so much trouble with that I opted for a rubber band to hold the top on. Even so, it's awkward to change batteries between flight, especially with those exhaust stacks catching on things.
Eventually I cut away a flap on the bottom and crammed the battery in, with the rubber band holding the flap. It's much easier now, but still enough of a nuisance that I don't fly the plane often.
I just used 1S 160 mah batteries.
Jim
Cool 15" Ultra-micro indoor balsa plane K4 SE5A display on Beijing Show and become popular DW Hobby Balsa Builders 5 Sep 25, 2016 05:32 PM
Discussion Peanut SE5A Dihedral? Mcgivern Scratchbuilt Indoor and Micro Models 3 Feb 07, 2010 12:39 AM
