Nov 07, 2017, 10:50 AM
Help!
DShot Beeper won't work with BF - Help needed
Hello,
i have Wraight32 ESCs wich support DSHOT and DSHOT Commands. I have flashed BF 3.2.1 on Omnibus F7 (v1) and Beeping with DSHOT works on startup for Flight Controller Startup Sound and ESC init (when i plugin battery).
But i would like to use DHOT beeper on a switch to enable beep to find quad better in large gras. I know it's impossible if it's armed, but on unarmed it's not working too for me.
Can anyone help please?
Nov 08, 2017, 06:50 PM
inverted-i-fly
3drcparts's Avatar
I take it you have set up a switch that is working on mode screen, have you turn on RX_Set under the beeper tab in configuration
Nov 13, 2017, 10:59 AM
You need to set the dshot beeper tone (or something like that) type "get beep" into the CLI and you'll see the one I mean. I set it to 3, that seems to do the trick
Nov 13, 2017, 11:13 AM
Team AlienWarpSquad
Does the ESC Firmware Support Dshot commands to beep??
Discussion JR 331 servo won't work with Spectrum Slopemaster Radios 20 Oct 22, 2017 11:40 PM
Discussion WOW! Mueller is so far off the reservation that even the IRS won't work with him.... Dave Campbell Life, The Universe, and Politics 46 Sep 30, 2017 03:29 PM
Mini-HowTo my JJRC-1000 won't work with my LS-model controller seanny Multirotor Drone Talk 0 Mar 18, 2017 02:47 PM
Discussion ESC Won't Arm - CC BEC Won't Work With Stock ESC??? annarelli Electric Heli Talk 6 Apr 14, 2010 02:56 PM
Why won't my Kontronik Sun1000 work with 480 motor sgil2001 Power Systems 6 Nov 04, 2001 09:37 AM
