Nov 07, 2017, 07:16 AM
Connector arcing
Guys
After having just recently completed the assembly of my 3m Hybrid/Lucas/6S Lipo PPG, I have a serious question for you experienced types.
Do you guys have any concerns regarding the arcing that occurs when plugging/unplugging the 22.5volt motor battery!?!?
I am using EC3 connectors, is this a common situation with these connectors?
Kenda
Nov 07, 2017, 11:31 AM
RC Paraglider / Sailplanes
Charlescd's Avatar
Hi Blake,
No problem on my end using 4mm bullet plugs. (not a big Arc)
The arc is only on the end and will happen with anything over 5s. You should see the arc on a 12s setup.!!
It's all part of Lipo life
the only way to stop the arc is a Spark Arrestor or eliminator.
Nov 07, 2017, 11:57 PM
These are great too... I use them on 8s and 10s setups.
http://www.espritmodel.com/jeti-afc-...s-4mm-75a.aspx
Nov 08, 2017, 05:23 AM
Charlescd's Avatar
Nice. Simple and easy to use.
Nov 08, 2017, 07:30 AM
Thanks guys, very much appreciated!
Discussion FPV Equipment molex connectors! Pls make a universal connector! Makimies FPV Equipment 3 Jun 09, 2016 05:28 PM
Discussion Syma X5C Battery Connector Arcing Sloan Mini Multirotor Drones 5 Feb 15, 2015 08:33 AM
Discussion Bullet Connectors with Arc 28-47-1.5 Abrams Flying Wings 2 Oct 12, 2010 12:10 AM
Discussion 4.2x4 versus 4.1x4.1 with ARC-110 and ARC-130 motors Nethole Power Systems 9 Feb 19, 2007 09:50 AM
Question Arcing Deans Connectors lammy1000 Mini Helis 5 Dec 16, 2006 10:47 PM
