can anyone identify this motor? - RC Groups
Nov 06, 2017, 04:58 PM
it has no marking or numbers . I was hoping someone could spot it and give me some info .
possibly fms ?
Nov 06, 2017, 11:36 PM
manuel v's Avatar
maybe a T turnigy.
Nov 07, 2017, 06:27 AM
cool thanks . would there be any marking inside once pulled apart ? like kv? I want to try it in my 1400mm corsair
Nov 07, 2017, 05:38 PM
manuel v's Avatar
Is necessary to test and read.
Probando un Motor. No load. (0 min 43 sec)
Nov 13, 2017, 05:12 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
Originally Posted by doug14
Would there be any marking inside once pulled apart ? Like Kv? ...
No markings inside motors.
Conservative rule of thumb for motor power: 3watt/gram.
Four simple methods for determining Kv
www.bavaria-direct.co.za
→ motor constants
Vriendelijke groeten Ron
Nov 14, 2017, 07:56 AM
Jack
jackerbes's Avatar
The weight of the motor and the Kv from a no load test will pretty much tell you all you need to know about a motor. And if you are working with a found/used motor the no load test will usually verify that it is in running condition.
If you don't have a watt meter yet you can use a DMM and run the motor up two times, measure the voltage on one and the current draw on the second and then Volts x Amps = Watts.
And you can get a DMM for free from Harbor Freight this week if you sign up to get their flyers by mail. They have a bunch of sales and flyers with free things on them, one current one is good for a free DMM!
Jack
Question Can anyone identify this 6A (I think) ESC ? tware Power Systems 4 Oct 18, 2015 02:03 PM
Question Can anyone identify this p-51? SilentMatt Fuel Plane Talk 3 Oct 05, 2015 11:09 AM
Discussion Can anyone identify this plane montyb101 Vintage & Old-Timer Designs 6 Sep 29, 2015 04:20 AM
Discussion Can anyone identify this plane hellocopter Vintage & Old-Timer Designs 16 Sep 21, 2015 10:43 PM
Discussion Can anyone identify this plane? hellocopter Electric Plane Talk 5 Sep 18, 2015 08:02 PM
