Octo Rotor X Build - RC Groups
Nov 06, 2017, 04:48 PM
Octo Rotor X Build
trying to build a Octo Rotor X and having an issue of which way the props should spin
some say that the top rotors should all spin CCW and all the bottoms should spin CW
I tried this method and it would lot lift
others say that if the top motor is CW then the bottom motor should be CCW and visa versa
any feedback would be greatly appreciate
Nov 06, 2017, 08:17 PM
What flight controller are you using?
Nov 07, 2017, 09:43 AM
I am useing a naza m v2
according to the motor test I have all motors turning the correct way
all the tops are CCW rotations and all the bottoms are CW rotation
all the 8 props are of the same pitch and make which concerns me
I use dji props and all 8 of them have the silver cap for this build
on my other quads again I use dji props there is a combination of props that have the silver and black caps
I would have thought in this build it would be of all different combinations of prop types or pitch
I can not get the quad to lift is the problem
Nov 07, 2017, 04:06 PM
NAZA setup diagram shows top props turning CCW and bottom ones CW. Also be aware that the bottom set of props should be inverted with respect to the motors. The bottom props must be CW props. You cannot use the DJI props with built in nuts because they must be mounted inverted on the motor and the thread is wrong. The bottom motors must have a right hand thread to be self tightening. Easiest way to do this is to use props with a through hole (no threads) and use nylock nuts to hold them on the motor shaft. Some insist that the lower set of props should have a smaller diameter and a steeper pitch for best efficiency.
https://static.rcgroups.net/forums/a...1-Untitled.jpg
Nov 08, 2017, 07:35 AM
so is it safe to say that I can use the props with the self tightening nuts for the top then
Nov 08, 2017, 02:30 PM
Yes. I built a coaxial Y6 and was able to use 3DR Iris props. The nut is not molded in but pressed in with two pins. They can be flipped over or swapped with the opposite rotating props.
Discussion Mini Octo Build propflux01 Scratchbuilt Multirotor Drones 8 Jul 03, 2016 03:57 PM
Discussion Tools to have for a heavy octo build? lylefk Beginner Multirotor Drones 3 Apr 21, 2016 05:39 AM
Discussion Proto X, Q4, X4, Dart Two Color 3D printed "X-Octo box" flyingj Mini Multirotor Drones 8 Oct 03, 2014 01:44 PM
Discussion quad x hexa x octo juliobarbosa Brazil 0 Jan 13, 2013 04:12 PM
Build Log (MA)Miniature Aircraft Carbon Fiber Rotor X 404 Quad Build Z06 Tony Multirotor Drone Talk 73 Jun 16, 2012 11:00 AM
