After my smoking failure yesterday.... - RC Groups
Nov 06, 2017, 08:01 AM
So after my epic failure yesterday, watching the boat I built for my boy going up in smoke in the middle of a pond due to poor esc selection amongst other things, I just wondered if someone could look over what I bought for my own boat project, as id really narked if this one went up in smoke too!
Its a much bigger boat, well a bit bigger. Its a 30 inch deep v. I'll be running 3s. I haven't got as far as prop selection yet.
https://hobbyking.com/en_us/turnigy-...ess-motor.html
Specs:
Can Size: 540
RPM/v: 3500kv
Poles: 4
Max voltage: 11.1 (3S)
Max Current: 60A
Max Watts: 400w
Resistance: 0.0155ohm
No Load Current: 3.1A
Can Diameter: 36mm (actual motor diameter)
Can Diameter inc. Water Jacket: 44mm
Can Length: 49mm
Shaft Size: 3.175mm
Weight: 234g
https://hobbyking.com/en_us/turnigy-...r-cooling.html
Specs:
Voltage Input: 2~3 LiPoly cells (4~9 NiMh)
Continuous Current: 60A
Burst Current: 360A
BEC Type: Linear with on/off switch
BEC Output: 6V@2A
Motor Connectors: 3.5mm
Servo lead: JR style
Servo Lead length: 250mm
Water Cooling Pipe: 2mm I/D~4mm O/D
Dimensions: 60.5x38.5x25.6mm
Weight: 84g
Any thoughts would be most welcome :-)
Nov 06, 2017, 02:56 PM
Have you considered taking up sail boats rather than powered?
Cheers,
Terry
Nov 06, 2017, 03:22 PM
Just Plane Nutts
AirDOGGe's Avatar
You will want at least an 80A or 90A with that 60A max. motor to obtain some current headroom. KV for the motor is a bit high for the use, but you may be OK if you keep the prop diameter smallish, say 37mm - 38mm. If it runs cool like that, then experiment with larger props.
Nov 06, 2017, 03:30 PM
Haha you might be onto something there Tony!
Originally I only wanted to build it, had a mad urge to build a boat so I bought some wood and built it. It sat unpainted in a cupboard for a year until my son hassled me in to finishing it, and here I am lol.
Nov 06, 2017, 04:33 PM
Mopar Musclecar fanatic
xx29l9's Avatar
And don't forget to put a fuse inline....better to blow a fuse than let the magic smoke out.
Bob
Nov 07, 2017, 03:27 AM
And what amp for the fuse for say that motor listed up there?
Burst Current: 360A
Discussion Received my F210 yesterday. Plugged in charged battery. Puff Smoke StoneDeaf FPV Aircraft 2 Nov 20, 2016 12:44 AM
Discussion After the 2nd smoke/burnt wires, I need help w/ my simple FPV Setup! dan07110 FPV Talk 8 Feb 20, 2015 04:58 PM
Discussion Obama; Racking Up Failure After Failure After Failure.... Highflight Life, The Universe, and Politics 86 Aug 23, 2011 01:28 PM
Is my esc fixable after it smoked? argarre Power Systems 2 Oct 02, 2004 08:18 PM
