Nov 06, 2017, 07:08 AM
Quad Erat Demonstrandum
scousethief's Avatar
Reptile Flight Controller For Swallow-670 S670 S800 Grey RC Airplane PNP Version
https://www.banggood.com/Reptile-Flight-Controller-For-Swallow-670-S670-S800-Grey-RC-Airplane-PNP-Version-p-1221963.html
Manually adjusted 3 axis flight controller
Description:
Brand Name: Reptile
Item Name: Flight Controller
Type: SMD
Dimension: 52x40x4mm
Input Voltage: 3S-6S (7-28V)
Output Voltage: 5V/9V
Output Current Peak: 3A
DCDC Conversion Efficiency: 92%
Full Load Output Ripple Vpp: <50mV
Output Accuracy: ± 0.1V
No-load Current IQ: 0.5mA
Cooling Method: Natural cooling
Operating Temperature: -40 ℃ ~ +85 ℃
Storage Temperature: -40 ℃ ~ +125 ℃
Relative Humidity: 20-90%
PCB Layers: Double panel
Flight control Voltage: 5-6V
Supported Aircraft Type: Normal / V-Tail / Delta Wing (Switches via Jog Jumper Weld)
Mode of work: ordinary stability / lock mode / off
Application: Suitable for Reptile S670 and S800 Grey version RC Airplane, NOT suitable for S800 Black version.
If you want to order S800 Black version Flight Controller,please Click Here
Package Included:
1x Reptile Flight Controller
Oct 10, 2018, 10:41 PM
John Hendry
HK has a good price on the Reptile renamed the Swallow and fixed the mold so no more front spar EPP that needs to be cut out.
New Product [New Arrival]Reptile S800 V2 SKY SHADOW 820mm Wingspan FPV Flying Wing RC Airplane BG Tobey FPV Aircraft 695 Oct 18, 2020 01:39 PM
New Product Reptile Swallow-670 S670 Grey 670mm Wingspan EPP FPV Wing KIT / PNP Justapoke FPV Aircraft 6 Jun 22, 2020 08:28 PM
New Product Reptile S670 SWALLOW Grey 670mm Wingspan EPP FPV Wing Racer - KIT and PNP Justapoke Flying Wings 18 Jul 30, 2019 05:11 AM
New Product Reptile Swallow-670 S670 - 670mm race wing Frimen Flying Wings 2 Jul 06, 2018 06:01 AM
