Valentijn 1:7 - RC Groups
Nov 05, 2017, 11:22 PM
Valentijn 1:7
Here’s a nice project I’ve been working on: It’s a 1:7 scale model of a Dutch lifeboat, is to be fitted with a 50 CC Blata driving twin 54 mm jets thru a MHZ gearbox. The model is 60 inches, built in glass/carbon epoxy/PVC foam. On DWL she should weigh about 25 kg, so I’ll probably have to add some weight to keep it in the water
Best regards,
Haje74
Nov 06, 2017, 01:22 AM
Some pics of the original:
Nov 06, 2017, 01:24 AM
Now that is what you call jet pump..do those 52's come in that colour now or have you had it anodised or painted?
Nov 06, 2017, 01:26 AM
Looking at the hull I would say it self rights like the original full size?
Nov 06, 2017, 03:42 AM
Hi, no these are Chinese 54’s (they’re based on the old MHZ Race unit) I was able to get cheap and that I upgraded myself with SS-Ceramic bearings and lube-points front & back. Also added the SS ring placed over the front bearinghousing and canpainted them.
BR,
Haje74
Nov 06, 2017, 03:43 AM
Yes it should; havent tested that yet though
Haje74
Nov 06, 2017, 05:56 AM
Nov 06, 2017, 07:55 AM
I see it's a vectored drive,is there a reverse bucket for them?
Is that a water pickup nipple at the rear for cooling purposes or the rear lubrication point?
Nov 06, 2017, 08:04 AM
I plan to make the reversebucket myself.
Yeah thats the water-pickup.
Lube nipple is in the back of the stator
Nov 06, 2017, 01:00 PM
Kayaker's Avatar
Haje74, your hull build is very inspiring. That much “glass work” takes skills. I also like the way you did the grease fitting for the stator bearing. If you don't mind, I would like to try that in the 45mm jet drive I will soon put in a “glass” (Kevlar) hull I'm building.
Nov 06, 2017, 01:31 PM
Just Plane Nutts
AirDOGGe's Avatar
Beautiful work. Looking forward to seeing the final results.
Nov 06, 2017, 01:40 PM
Thanks for the compliment.
Here’s some pics of the build sofar:
Nov 06, 2017, 01:53 PM
Sure! I only got the idea by looking at pictures of jetunits by MHZ anyway (I used the SS type)..
Nov 06, 2017, 08:04 PM
That is a big hoss!! Can't wait to see this finished.
Nov 07, 2017, 12:14 AM
The project has been on hold for some time until recently. Now, with the completion of the 2 drives I plan to restart the build.
Discussion Smartmodel scale pilot figure 1/6,1/7,1/8 ,1/10 kin Scale Helicopters 13 Feb 16, 2017 12:46 AM
Discussion GOLD $1,435 an Oz.....7/18/11 now $1,600 an oz. 8/8/ 11 now $1.700 an oz. realtimerecon Life, The Universe, and Politics 136 Sep 05, 2011 03:54 PM
Discussion B50-7S+6,7:1 or Kira 500-26(or 30)+6,7:1 ? pabork High Performance 4 Sep 23, 2009 07:59 AM
Schweizer SGP 1-1 Primary, SGU 1-2, 1-3, 1-7, 1-19, and 1-20, 2-22 mmartin55 Scale Sailplanes 5 Jul 29, 2008 10:10 PM
Discussion Just 7 minutes of flight time then a 1-1 1/12 hr wait?? stratocu Beginner Training Area (Aircraft-Electric) 19 Jan 27, 2008 01:04 PM
