Trying to get the motors to turn - RC Groups
Nov 05, 2017, 10:12 PM
Help!
Hi everyone,
I'm currently getting crazy with my quad copter because I can't get the motors to turn. I connect them to the ESC and they beep doing be be be showing that they are connected. However, the arming sequence doesn't work and the motors don't turn.
Drone specs
Receiver: FrSky X8R
Remote: Taranis Q X7
Flight controller: Naza M Lite
ESC: Cicada 4 in 1 30Amps
INFO about current situation:
The receiver and remote are correctly bounded and you can see a solid green light on the receiver. The flight controller has been connected to a computer and you can see on the Naza assistant that when you move the remote's levels there is a reaction so everything seems to be set up correctly using the S-Bus.
EDIT: I have bypassed the flight controller connecting the receiver and ESC to the power supply and a dummy servo tester got the motors to turn so they're able to recieve a signal and move.
If anyone has any idea about what's going on, it'd be very very helpful to let me know so I can test it out and reply with the results.
Thank you!
Last edited by Juanda1995; Nov 06, 2017 at 04:23 PM. Reason: Update about progress
Nov 07, 2017, 01:36 PM
Culper Junior
You are in the wrong forum.
Post your question here.....https://www.rcgroups.com/forums/show...-building-Quad
Nov 07, 2017, 03:48 PM
UNDERSTOOD. I'll do it. Thanks for the input.
Discussion First build from parts on f330 frame, trying to get my head around motors and props Tachikoma Beginner Multirotor Drones 7 Jan 21, 2017 02:02 PM
Help! How to get more turns for a rubber motor with less torque? ineffablee Balsa Builders 4 Nov 13, 2016 10:54 PM
Discussion tri is rolling left when I yaw right during a banked turn.....KK2.1 rcminiman Tricopter Drones 12 Sep 30, 2015 01:00 PM
Discussion Has anyone tried the 13.5 turn brushless motors? dooky Electric Power Cars 3 Dec 01, 2007 10:20 PM
Question Anybody tried using a WARP 4-2 Turn motor with 3 Lipoly on a MF 480 ? chrisc Electric Ducted Fan Jet Talk 3 Sep 29, 2006 04:27 PM
