Nov 05, 2017, 10:40 PM
Lipoly Killer
Frank Hurd's Avatar
Servos
Folks,
I have a Tacon 160 in a Old Variant. It has 1200 square inches in wing area and weighs 14 lbs, running 10S and a 19/10 APCE prop. I have some Power 1501 servos. Anybody have any experience with these servos? If I change to digitalis, what would be a good alternative? Given, of course, not $100 servos!
Frank
Nov 06, 2017, 10:27 PM
vollrathd's Avatar
Originally Posted by Frank Hurd
Folks,
Frank
Check out the Hitec 645MG servos at around $30 each. I use them in my two models running 2200 and 2800 Watts. These models also have flaps. These servos have been flawless.
https://www.towerhobbies.com/cgi-bin...&I=LXUZ89&P=ML
Ref:
Giant Scale Big Stick Conversion (Been flying for six years)
http://www.wattflyer.com/forums/showthread.php?t=65052
Great Planes Giant Escapade Z(Been flying for two years)
http://www.rcgroups.com/forums/showt...5#post32798968
Hitec 5645MG Digital Servos
https://www.towerhobbies.com/cgi-bin...&I=LXUZ80&P=ML
This 4500 Watt model is using the Hitec 5645MG Servos
Giant Corvus Model
https://www.rcgroups.com/forums/show...-Models-Corvus
Nov 07, 2017, 05:57 PM
Lipoly Killer
Frank Hurd's Avatar
Thank you!
Thank you for your info!
Frank
Nov 07, 2017, 06:13 PM
vollrathd's Avatar
Frank
You're welcome. Just be sure to use a solid receiver/servo battery supply for your model. Castle Creations 10 Amp BEC's or two cell 2500 Mah A123 batteries work well.
What I did on my 12S2P A123 motor bsttery packs was to hook up the 10 Amp CC BEC to the "LOWER" A123 pack.
Question Servo (Turnigy Servos) jobinseattle Beginner Training Area (Aircraft-Electric) 7 Jan 17, 2016 03:58 PM
Discussion airplane servos for steering servos? ZipSnipe Car Talk 8 Jan 10, 2016 11:29 PM
Discussion Servo recommendation for digital 9g servo? cjbucher Radios 17 Nov 03, 2015 10:24 AM
Discussion Do I need to do a servo calibration after replacing my servo? Noobie1 Micro Helis 4 Oct 14, 2015 09:19 AM
Question Servo arm/output shaft slop in modelle-Expert (Mexx) 85 BB MG servo Squinton Radios 0 Oct 03, 2015 09:31 AM
