Nov 05, 2017, 04:21 PM
Build, Fly, Crash, repeat
big_poppa4904's Avatar
What servo for ailerons on Ultra Stick .40?
I think my servos are going out on my .40 ultra stick on the ailerons. What are some decent (budget) servos to put on it? Not looking for top of the line servos here as this is just a stick plane, just want something that has been a good servo that you guys have tried.
Nov 05, 2017, 04:32 PM
Me Likey Scale Planes
scale_only's Avatar
These are a nice upgrade to standard servos that I've used on 40-60 size planes,,, and they don't break the bank,, https://www.towerhobbies.com/cgi-bin...&I=LXDTB3&P=ML
Nov 05, 2017, 05:51 PM
Hmm, what do you think about this servo. It's what I use in my RC crawlers. Seems like if it's good enough for a crawler it would be good enough in a plane. It has alot more torque than the one you linked, but the speed is the same.
It is a digital servo. Does it matter if I use digital or analog?
https://rover.ebay.com/rover/0/0/0?m...2F132244887872
Nov 05, 2017, 05:53 PM
Here is the same servo, just a different link in case the other don't work
https://rover.ebay.com/rover/0/0/0?m...2F332246385881
Nov 05, 2017, 06:09 PM
AMA 537620
ChillPhatCat's Avatar
This is all the servo you need:
https://www.towerhobbies.com/cgi-bin...&I=LXDEL7&P=ML
Latest blog entry: Ready for test flight
Nov 05, 2017, 06:10 PM
Gepat's Avatar
For a 40 size try Hitec HS322HD around $17
Nov 05, 2017, 06:26 PM
That's more like it. Especially for this plane. I understand for 3D planes they need high torque servos. But for these small ailerons on this plane I figure wouldn't need much
Nov 06, 2017, 07:18 AM
AMA 537620
Originally Posted by gepat
for a 40 size try hitec hs322hd around $17
Originally Posted by chillphatcat
x2
Nov 06, 2017, 07:44 AM
The Futaba has more torque than the Hitec. 72 vs 51 ounces.
You can find all the specs on them at Servo City.
https://www.servocity.com/
Nov 06, 2017, 10:08 AM
AMA 537620
The Hitec HS-322HD costs $12.59 at Tower vs $22.99 for the Futaba 3010 at Servo City. I see my link is broken now, however.
There is no reason to put 72 oz on a single aileron for a .40 sized plane. He could put an HS-81 in there as well and still have plenty of authority.
Edit: In fact it's $11.49 at SC.
Nov 06, 2017, 10:21 AM
scale_only's Avatar
The reason I suggested the 3010 is that the OP said the servos he was using "are going out",, one would assume he is using standard servos and they aren't holding up,, thus maybe an upgrade is in order,,
It's interesting to note this is the servo the manual recommends https://www.horizonhobby.com/product...-servo-jrps821
Life is full of choices
Nov 07, 2017, 02:12 PM
The load draw is way lower on the 322 than even the most economical digital servos. Analog servos still have plenty good applications.
Help! Mini Ultra stick chord and aileron measurements??? ozmo01 Sport Planes 4 Aug 31, 2016 10:01 PM
Discussion Flush mounting winger servos on a Ultra Stick 40? spacecase Fuel Plane Talk 10 Dec 26, 2014 02:58 PM
Discussion Aileron servos for G.P. Ultra Sport 40 Bill Smudge Sport Planes 5 Feb 27, 2014 05:46 PM
Discussion Mini Ultra Stick - Aileron Servo Question reyn3545 Electric Plane Talk 9 Jul 09, 2006 01:51 PM
What are the drawbacks to installing a OS .91 FX 2-stroke on an Ultra Stick 40? oxygen728 Fuel Plane Talk 13 Aug 12, 2005 01:30 AM
