Flair SE5A Building- Diary - RC Groups
Nov 05, 2017, 12:18 PM
avionette's Avatar
Hello
Sorry my english limited....i will show instruction picture. Plans picture etc.
I start glueing parts 1 to 2 but the just enlarged the seat of n 3 because do not go inside
Nov 08, 2017, 08:51 AM
avionette's Avatar
After glued a pair of forward fuselage it got warping . I resolved momentarily puttin fuselage sides in the water (because it returns crooked after 5-6 days).
I got 2 kind of warping look picture2 and 5
Nov 08, 2017, 09:41 AM
Nergall's Avatar
Maybe I'm lazy about this, but that warp seems insignificant to me in this context. Likely, you will be bending it a bit in your fully assembled fuselage anyway? Either way, a proper self supporting fuselage structure should hold the side straight once everything is assembled?
Nov 09, 2017, 12:07 PM
fairweatherflyer's Avatar
once you have exhaust stacks on- they may well reduce the impression of the warp. Doesn't look too bad and once solartex is applied and shrunk to the outer side that may well help pull out the warp. Its a great flying plane, used to fly one with my Dad several years ago.
Nov 10, 2017, 07:16 AM
Curious what kind of glue you used on those fuselage parts?
Next time use a medium speed epoxy spread on the entire part. And place it under something flat and fairly heavy while it cures.
To fix this one, I doubt it really needs it but, you could glue a couple of hard wood stringers to the inside of the piece. 1/8 x 1/8 should do it. Use epoxy for this and clamp things to hold it flat. Other way, depending on the pieces would be to simply make new parts. Maybe make a single piece from a thicker balsa vice the laminated one.
On second thought, skip the stringers. I suspect you have another frame member that should do the trick. Just go slow when the time comes and clamp it well.
Dec 06, 2017, 12:54 PM
avionette's Avatar
I resolved the last warp putting the former n 18
Flair SE5A Albatross Scale Fuel Planes 21 Nov 05, 2017 12:56 PM
Question Flair SE5a 53" Kit plans and Instructions LostCrusader Balsa Builders 0 Sep 24, 2016 08:49 PM
Help! Flair SE5A Building Instructions Atindra Scale Kit/Scratch Built 1 Dec 01, 2015 01:01 PM
Help! flair se5a ufo jerry Scale Kit/Scratch Built 3 Nov 19, 2009 07:40 AM
