Anyone using folding multicopter props? - RC Groups
Nov 05, 2017, 12:00 PM
I wonder if anyone have using folding multicopter props ,for exampel on a quadplane?
Nov 07, 2017, 10:52 AM
Ran D. St. Clair's Avatar
Not me, but as far as I know they work just fine.
Nov 07, 2017, 12:18 PM
Do you know if it makes any difference regarding flight time/power consumption in plane mode?
Nov 07, 2017, 12:39 PM
As far as I know it does not. I would say it is mostly a convenience for transport. There are some slight benefits in terms of balance and some slight disadvantages in terms of complexity (more pieces to break or get lost). I am not sure how you would balance the blades short of pinching the hubs. The more complex techniques used for helicopter blades are probably not necessary until or unless you get into very large rotors. Flight controllers are getting very good at rejecting vibration effects, but video cameras can still have "jello" if there are vibration issues. That being said, many of the camera platform type drones have folding props so it seems to not be an issue. i guess you could still do various dynamic balancing techniques if you had to, but that is more hassle than most people bother with or even need to bother with.
Nov 08, 2017, 10:49 AM
Ok.When I look around I find the Deltaquad (it has no folding props),and they get 2 hours flight time,and they seems to have spent a lot of time on
testing it. So it seems not affect flight time worth bother it.Thank you anyway for reply
Nov 11, 2017, 09:15 PM
Soap Box Junkie
admodesi's Avatar
As getting matching "powered glider" style CW and CCW folding props is next to impossible, I am going to manufacture my own. The idea being you can shut some or all the motors down and create less drag and use less power when in FF mode, as it has been done by others before.
Nov 19, 2017, 01:06 PM
I mean folding multicopter props (I thought not to tilt motors ) they can be found as CW and CCW
Nov 19, 2017, 03:09 PM
You didn't say, but I assumed you wanted the blades to fold back in the airstream to reduce drag when in forward flight. Depending on where the motor stops, they might not fold in a way that is helpful. Regular fixed blade props can be relatively low drag if they stop in line with the airflow. That can be done in various ways including magnets on the motor housing.
Nov 21, 2017, 01:48 PM
Sorry for not explain.And yes I also think it could be a issue that the blade might not fold depending how the the motors stop.
I just was curious ,if anyone had some experience regarding using folding multicopter props on the lift motors.
Nov 24, 2017, 06:25 AM
Soap Box Junkie
admodesi's Avatar
I agree with Ran D St Clair, you'd be better off figuring out how to get your props to stop with a fixed (two blade) prop aligned with the airflow if your lift motors don't tilt. I initially thought you might just want them to fold for transport or storage, but folding during flight is probably a bad idea.
Help! confused with using folding props maxfive Electric Plane Talk 8 Oct 12, 2017 11:20 AM
Discussion Lynx FPV Folding Props...anyone flying them? Jonathan Ott FPV Racing 1 Mar 14, 2017 02:41 PM
Question Anyone know a good source for folding prop/hubs? NewZee Sailplane Talk 8 Mar 17, 2016 10:27 AM
Question How to use folding props? Loganj13 Multirotor Drone Talk 3 Sep 17, 2015 02:53 PM
New APC folding props - Anyone seen or used ? Mark Sanders Sport Planes 8 Mar 04, 2002 07:59 PM
