This thread is privately moderated by ariaAQ, who may elect to delete unwanted replies.
Nov 05, 2017, 10:29 AM
ariaAQ's Avatar
Mini-Review
DYS BE5208 330kv Thrust Test 6S 1755
Good quality motor for big copter, with long wires..
Here's my thrust test video, tested several months ago, sorry about the lighting
DYS BE5208 330kv Brushless Motor Thrust Test 6S 1755 (2 min 37 sec)
Manufacturer Specifications:
KV: 330
Configu ration: NP
Stator Diameter: 52mm
Stator Length: 8mm
Shaft Diameter: 5.0mm
Motor Dimensions: Φ63x30mm
Weight: 200g
No. of Lipo Cells: 3-6S
Max Continuous Current: 28.2A
Max Continuous Power: 626W
Internal resistance: 0.106Ω
Nov 05, 2017, 10:32 AM
ariaAQ's Avatar
Test condition:
- I use cheap 1755 carbon fiber propeller, i think can produce more thrust and more efficient with good quality props.
- I live in Bandung, West Java, 800m above sea level
- Battery 2x5200mAh 3S 30C in series, (not fully charged)
- ESC FMS Predator 50A
Summary:
- Good quality,
- Smooth bearings,
- Powerful,
- Efficient,
- Can use 16"-18" propellers,
- Long wires (30+ cm),
- Prop mount 2 x M3, 12mm spacing
Here's my test result:
Discussion DYS BE1806 Thrust Tests Mustang7302 Mini Multirotor Drones 699 Nov 10, 2019 04:18 PM
Discussion DYS 1104 vs RCX 1105 Thrust test v3r73x Multirotor Drone Power Systems 53 Jul 22, 2017 01:04 PM
Discussion New DYS SE2205 2300KV 1.22KG thrust test. Liliass Multirotor Drone Power Systems 618 Sep 11, 2016 06:15 AM
Data Dys be1806-2300kv thrust test deno6031 Multirotor Drone Power Systems 3 Feb 20, 2015 06:09 AM
Data Dys be1806-2300kv thrust test deno6031 Mini Multirotor Drones 0 May 23, 2014 09:41 AM
