This thread is privately moderated by beaujack, who may elect to delete unwanted replies.
Nov 05, 2017, 10:01 AM
Help!
Help selecting servo with the correct torque
Good afternoon all, i need help selecting a servo that has adequate torque and speed for my model, i have an alfa models micro p-51 mustang, the instructions recommend 3 gram servos but unlike other alfa models does not give the minimum torque requirements (does say not to use linear servos) i would like to use the lightest servos as possible, below i have put all the info i have on the control surfaces, auw of airframe etc and the servo i would like to use and also a youtube link to a video of the model, if someone can help me out with what i need, i would be very grateful
Wingspan: 460mm/18.11in. Wing area: 3.7dm2/57.4sq.in. Weight: 65 grams/2.3oz. Motor: 7gram 2000kv brushless outrunner. Elevator: 165mm/6 1/2" width, 2mm thick at leading edge, 14 sq.cm area, 6mm deflection up and down, pushrod controlled. Ailerons: 90mm/ 3 1/2" width each, 3.5mm thick at leading edge, total area 23.4 sq.cm, 6mm deflection, both ailerons controlled by single servo via two pushrods.
Here is the servo i was thinking of using; Tactic TSX1.9 coreless Weight: 1.9g Torque: 0.17kg.cm @4.8v Speed: 0.04sec/60 degrees @ 4.8v
Here is the youtube link for flying characteristics and general speed envelope:
Alfa Models Micro P-51 Flight (2 min 2 sec)
Discussion I need help selecting 6g servos Scott in NH Servos 4 Nov 09, 2016 10:29 AM
Question Help with 12 Foot Wingspan Servo Selection Tychoac Giant Scale Airplanes 5 Dec 20, 2015 10:26 PM
Discussion Servo Selection help bh1989 Electric Ducted Fan Jet Talk 7 Dec 16, 2015 11:50 AM
Discussion Help with ordering correct antennas and transmitter Beatwolf FPV Equipment 4 Sep 30, 2015 07:47 AM
Discussion help me to select the correct motor Mike_eee Electric Power Systems 3 Oct 14, 2007 12:20 AM
