Nov 04, 2017, 10:21 PM
Buying a used 4 stroke. What to look for
Hi everyone,
I've found a plane for sale locally that I like and it comes with a saito 72. The seller was an experienced rc'er long ago and he built and ran the plane with the engine. He said that the plane has been sitting in the closet so center 2003.
Looking at the engine it looks fine and don't see anything that screens trouble .
Problem is I have no idea what to look for in terms of buying the engine (how to check for compression etc).
If anyone can give me tips on what to look for before buying I would be grateful.
A.J.
Nov 04, 2017, 10:28 PM
SeismicCWave's Avatar
Originally Posted by p51mustanglover
Hi everyone,
A.J.
Sorry you can't tell until you run it. Compression can be checked with a compression gauge.
https://www.rcgroups.com/forums/show...ircraft-engine
But you can't check for rusty bearings and rusty crank shaft until you open up to look at the inside.
You just have to take a chance. Even the seller with the best intention can sell you a bum engine because the seller doesn't even know sometime.
Nov 04, 2017, 11:11 PM
Play that funky music right
kenh3497's Avatar
When ever I buy a used engine I figure the cost of a set of bearings in the price. With a four stroke (4C) often times the valves may be stuck open so the engine will have no compression. The best cure is to disassemble, clean re-oil and put it all back together. It's also possible the ring is stuck in the ring groove and that will also affect compression.
If the price is right, go ahead and buy the plane with the above in mind. I've been in the hobby since 1975 and have only worn out one engine. Maybe that's because I trade engines all the time. haha! Still to wear out an engine is not an easy ting to do. At the most you might need a new ring in addition to the bearings.
Ken
Nov 04, 2017, 11:15 PM
Depends how cheap it is . If it were me the very least I would ask is for the backplate to be removed . Its no biggie and its not like tearing down the whole engine . If they refuse I would keep on walking . Others will disagree but its my $ and thats what I would do . Cheers
Nov 04, 2017, 11:24 PM
A man with a plan
Balsaworkbench's Avatar
What kind of a deal is he giving you? If it's cheap enough, you don't need to worry. But if he's trying to squeeze a premium price out of you, you are entitled to see the engine running.
Nov 04, 2017, 11:51 PM
Ken
Thank you all for answering. He's asking 150 for the plane and the engine on it. He says he's got nothing to start it up. I've got nothing either because I've flown nothing but electrics.
Nov 05, 2017, 12:11 AM
A man with a plan
So it's a crap shoot.
Nov 05, 2017, 01:11 AM
David (dmrcflyr2) actually made a video about this particular question. Has a lot of good points.
How to: Tips for Buying A Used 4 Stroke Engine (6 min 1 sec)
Nov 05, 2017, 06:37 AM
https://www.youtube.com/watch?v=zWLzhoW2wSM
This is an awesome video
Nov 05, 2017, 07:17 PM
kenh3497's Avatar
So you will be purchasing a 15+ year old airplane that has been sitting for at least 15+ years. Time is not on your side of on the side of the engine or airframe. About all you can do is turn then engine over to see if it has compression. IF, it turns over that is a bonus. It's possible it may be stuck. If it turns over but no compression probably stuck valves. If stuck it's a crap shoot. I mention this because I would used these points as price reducers. Also look over the airframe for warps from setting in the closet. I'm sure "stuff" got piled against it likely warping flight surfaces.
In this area there are quite a few RC auctions. Very often complete air frames, ready to fly less RX, will sell for $100.
Ken
Nov 05, 2017, 07:21 PM
What plane is it?
Nov 05, 2017, 07:22 PM
I TOBOR's Avatar
Offer him 50 or 55 bucks for the engine sans the plane.
Nov 05, 2017, 10:51 PM
Club Saito | Genesis 8:11
Bunnyshooter223's Avatar
FA-72A & Air Leak Issue
I have had recent trouble with my current running .72A that has the old style plastic case backplate.
It does not have the extra rib on the carb mount and so is loose near the intake at the head.
Basically, the intake gasket has some play due to vibration/inferior carb mount. I am talking air leak.
I had the signs in David McIntire's video on air leaks and later realized the o-ring worked loose.
I was chasing needle settings whereas my FA-50 was easy to tune...
The newer plastic back plate has a rib near its carb mount.
I was recommended by those wiser than me to buy the FA-82 metal back plate, gasket, and metal carb screws as a proper replacement--which i prefer anyways
I could probably add spacers at the head/intake pipe/o-ring as a temp fix. I do not know the long-term results of this
It's a dang nice engine otherwise and sounds great. I think it pulls over 7 lbs. static
Nov 06, 2017, 06:37 AM
Engine man
dmrcflyr2's Avatar
Here we go with the useless compression gauge thing again.... SMH I also have a video showing how useless this tool is too.
Model Airplane Compression Gauge by Hobbico (5 min 11 sec)
Nov 06, 2017, 06:42 AM
I TOBOR's Avatar
Shooter, that O-ring on the intake pipe is supposed to be Viton not a regular O-ring. The Viton stands up to head temps better.
Discussion What size plane to use an OS .52 Surpass 4 stroke Assocracer Fuel Plane Talk 13 Jun 08, 2017 05:41 PM
Discussion New to FPV , Looking for guidance on what to buy/build JohnnyR FPV Talk 2 Nov 30, 2016 02:41 PM
Discussion Looking for a 6 cell charger what would you buy Zagabond Batteries and Chargers 31 Oct 29, 2016 04:36 AM
Discussion Looking to buy a used Nitro. What should I look for? TheDeltaFlight Car Talk 1 Oct 28, 2016 04:03 PM
Question What to look for when buying used mygt1 Off-road Cars 4 Aug 11, 2008 05:34 PM
