Low noise / efficient props - RC Groups
Nov 04, 2017, 12:18 PM
So, I saw you can buy the Mavic Platinum props from DJI, not too expensive, the 8331 low noise propellers, which are supposed to one of the reasons the platinum is more efficient.
Can you get props designed like that but in larger sizes? I am kind of curious in trying them out vs standard props of the same size and seeing how much of a difference it makes.
Nov 04, 2017, 03:02 PM
Efficiency increases when upsizing rotors and lowering RPM.
Discussion which is more efficient and safer for a motor :low KV high Voltage or opposite ? mohsenfjs Power Systems 35 Sep 09, 2017 07:18 AM
Question How low can you go with led current without loosing efficiency RC Aerobat Night Flying 0 Apr 21, 2016 05:10 AM
Discussion Best efficiency motor/prop combo? tobiasv08 Multirotor Drone Power Systems 22 Oct 06, 2015 09:45 AM
Discussion Large, low pitch prop at higher RPM or Smaller high pitched prop for efficiency? RS2K Power Systems 1 Sep 19, 2014 09:24 AM
Discussion tractor prop efficiency vs. pusher prop efficiency? larrysogla Engines 9 Mar 19, 2009 02:09 PM
