BAe Hawk T1 70mm EDF by Freewing - Page 2 - RC Groups
This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Nov 07, 2017, 11:45 PM
Lithium Member
Herb's Avatar
Canopy and pilot look nice in the Hawk, but I wanted something a bit more realistic without going overboard
I looked in my "pilots drawer" to see if I could find something suitable, and found a few inexpensive parkzone pilots that could do the trick ... They seem more or less to be the right size, maybe a tad too large but ... oh well.
Nov 07, 2017, 11:48 PM
Lithium Member
Herb's Avatar
Some very simple detailing ...
From the Hawk size (102cm wingspan or scale 1:9.75) one needs - by simple scaling - a pilot whose helmet is ~27mm in diameter, close to the one that comes with it, or almost exactly the Parkzone size one.
It seems to me that the RA Hawk helmet is only slightly larger than say a regular motorcycle helmet.
Nov 07, 2017, 11:50 PM
Lithium Member
Herb's Avatar
Finished product ... after a couple of hours of relaxing evening work
Nov 10, 2017, 12:17 PM
Lithium Member
Herb's Avatar
Size & shape comparison of the new 70mm FW Hawk to my beloved fat old Dumbo ear 90mm FlyFly Hawk in beercooler foam :
Nov 10, 2017, 12:19 PM
Lithium Member
Herb's Avatar
The sun has come out ,
Nov 15, 2017, 01:29 PM
Lithium Member
Herb's Avatar
The original Red Arrows BAe Hawks have a really glossy & clean look :
Which is of course not easy to replicate on a $160 foam model where the surface finish is good, but not perfect.
Nov 15, 2017, 01:34 PM
Lithium Member
Herb's Avatar
The surface finish out of the box is a nice matte red, I put on two coats of Johnson's Future water-based acrylic to give it a bit more shine
Nov 15, 2017, 04:02 PM
Build to fly, fly to fix
Bet you it goes a little faster too!!!
Nov 16, 2017, 01:57 PM
Lithium Member
Herb's Avatar
Maybe but probably not ... unless it gets a good sanding as well
Nov 17, 2017, 12:15 PM
Lithium Member
Herb's Avatar
Having a second inexpensive spare canopy available gives you the option of playing around with various setups
Nov 19, 2017, 01:07 PM
Lithium Member
Herb's Avatar
Three good flights on the Hawk yesterday ... even faster w/o the smoke oil tank
Anybody seen my silver plastic pitot tube ??
Nov 26, 2017, 07:45 PM
Lithium Member
Herb's Avatar
Bought two new HK zippy compact 60c batteries for the Hawk and the F-16 ... flew very nicely with the new batts ... finally burned up the ARC motor
Motor was ~3 years old I think, so it did a good service, very light & a lot of power.
I think one of the windings shorted, maybe too much heat.
Motor quit right after takeoff, went around 360 degrees with no power and had a perfect landing on the strip w/o flaps
Nov 26, 2017, 07:49 PM
Lithium Member
Herb's Avatar
Dug deep in my 70mm fan box and found two Freewing 70mm 12bl shrouds, they seem stronger (fiber reinforced) than that plastic CS fan.
Also found two CS 70mm 12bl fans, I think they are older V2 (vs newer V3).
But I did like the CS fan better than the Freewing one, the latter has a bizarre undercambered airfoil
Installed the HK Mad Thrust 2970 motor with four bolts at the front and support at the back as well, all secured with ge silicone ii.
Nov 26, 2017, 07:54 PM
Lithium Member
Herb's Avatar
New fan assembled with HK Mad Thrust motor, CS 12-bl rotor in Freewing shroud.
Checked for fan balanced on my test stand, then mounted in the Hawk
Re-checked the CG since the new fan & 2970 MT motor is heavier (motor 196g vs 87g for the old arc)
Nov 27, 2017, 10:23 AM
Vertical Unlimited
Straight Up's Avatar
Very comprehensive update, Herb! Will be interesting to see how your "melting pot" fan works out. Please advise what power it draws, and if you see a performance gain.
Alert Freewing BAE Hawk T1 70 mm The Snake Foamy EDFs 410 Today 05:30 AM
Discussion BAe Hawk T1 Matt Halton Large EDF Jets 8 Nov 16, 2017 02:13 PM
Discussion BAE Hawk - 70mm EDF Maiden flight jjmelo Electric Ducted Fan Jet Talk 1 Oct 24, 2012 05:04 PM
Discussion TFModel BAE Hawk 70mm EDF - Instruction Manual jjmelo Electric Ducted Fan Jet Talk 0 Oct 24, 2012 04:40 PM
BAe Hawk 70: 70mm Composite edf Mr. Boogie Product Announcements 19 Jan 21, 2009 10:30 AM
