Original Optic 6 problem - RC Groups
Nov 04, 2017, 11:56 AM
Retired and Lovin' it!
TPfingston's Avatar
Question
I have an Optic 6 which I like very much however it has recently developed a problem. When the throttle stick is moved upward, nothing happens until just before reaching the center of travel. At this point I get approximately half of the servo travel (or half throttle when connected to an ESC), next two clicks will produce another ten percent or so of travel, and the next click with produce the remainder of available servo movement (or throttle response on an ESC). The balance of stick movement does nothing.
I suspect a bad potentiometer on the throttle stick. Is this transmitter worth repair or should I just toss it and buy a new transmitter?
Tony
Nov 06, 2017, 12:34 PM
Xpress..'s Avatar
It does sound like a bad POT in the gimbal, we should be able to repair it if you send it into us:
http://hitecrcd.com/support/warranty-service
Latest blog entry: Multiplex 10% off sale!!!
Discussion Optic 6 and Electron 6 problem BOING Radios 2 Mar 30, 2007 06:24 PM
Optic 6 Problems - CP Output and Gyro Gain Switch lingenfw Hitec/Multiplex USA 0 Feb 28, 2005 09:58 AM
Help! Optic 6 Problem - Any Ideas?? devereaux Hitec/Multiplex USA 23 Jan 28, 2005 11:55 AM
Optic 6 problem? Shard Radios 6 Jan 27, 2005 04:21 PM
Optic 6 Problem devereaux Radios 11 Jan 13, 2005 11:54 AM
