Nov 03, 2017, 07:07 PM
Jonathan Wells
jonathan4000's Avatar
Question
Release System for Aluminium ?
I've made an Aluminium fin insert for my "Savage" composite flying wing.
Can someone please recommend a release system for this.
I only have experience with TR108 wax for composite and Corian moulds.
Thanks for your time
Nov 03, 2017, 09:30 PM
Ward Hagaman's Avatar
I use part-all wax and pva.
Nov 04, 2017, 03:19 AM
Entropy is happening!
Jim.Thompson's Avatar
I would use only wax.
There are no free radicals to cross link in aluminium, so no need for PVA.
Nov 05, 2017, 10:00 AM
Jonathan Wells
Thanks guys
Nov 06, 2017, 03:32 AM
Auzzie built planks
timbuck's Avatar
You should have no dramas with TR108. I have mates who have used it on aluminium also another freind meguiars also works fine. In resent times I've been using semi perm chemlease on aluminium and that is just awesome , parts just fall out as I split the moulds.
Also think joe manner use just wax (meguiars ) in the D130
Cheers
Tim
Latest blog entry: More colours
Nov 07, 2017, 05:24 AM
Rock Breaker
gazasmith's Avatar
I use tr108 on steel moulds works fine.
Dec 02, 2017, 07:35 AM
Jonathan Wells
Thanks guys
Dec 02, 2017, 07:42 AM
Jonathan Wells
First time machining Ali,
The endmill broke on the 2nd contour pass, so had to get the hacksaw out.
I'll be using TR108.
Dec 02, 2017, 08:58 AM
Rock Breaker
gazasmith's Avatar
Kero is the best lube for aluminium if you can't full flood coolant. Just spray bottle to mist on regularly. Other lite lubes like wd40 also work.
Some grades of aluminium are just a b...ch to machine they stick to your cutter.
Gaza
Dec 02, 2017, 10:16 AM
Jonathan Wells
This was machined on my Router, without coolant but with some blasts of compressed air. The roughing was perfect, really nice chips, the main form was also good.
I didn't realise the depth of cut I was trying to take at a high feedrate and no Air/coolant, I was half a second way from pressing the EStop - bummer.
New Product A26CHR AGF 26g Full CNC Aluminium case Digital Coreless Wing servo for Glider Camille.Zhang Product Announcements 0 Oct 17, 2017 06:38 AM
Help! Any suggestions for manufacture that can produce aluminium parts?! AleOdessa Vendor Talk 1 Mar 07, 2016 02:16 PM
Discussion Shop with EDF aluminium system Helicoy Electric Ducted Fan Jet Talk 1 Mar 13, 2011 06:07 PM
aluminium motor mount for hacker exowatt Electric Heli Talk 1 Nov 19, 2001 03:09 PM
