Nov 03, 2017, 02:11 AM
KISS ESC 32A (45A active limit) | Flyduino
Hi,
Today we released the new KISS32A ESC.
available at flyduino shop: https://www.flyduino.net/en_US/shop/...961?category=2
it comes with the same size as the KISS24ARE (19x27mm), but can handle 2-5S without external capacitor and 6S with a min. 220F 50V one. beside the more current (32-45A) it also supports more then Dshot2400 (2400 stable tested).
It uses the new STM32L4 which is a ARM-Cortex M4 with floatingpoint unit. it can measure the current more accurate and much faster then the F0. so its much safer against overload.
for smoother running it now does sinHybrid which is a mix of sinusoidal and backEMF. like that it keeps all benefits of using backEMF, like it runs every motor without knowing it, it can run very high eRPM's like 500k and it adapts to any changes (motor characteristics changes after crash) where full sinwave (FOC) would get problems. but it also switches the motor phases with sinwave foram, so it produces less noise and the motor can run more round and might produce less vibrations. to not loose some KV (which would be normal with sinwave) it fades to trapezoidal after abaut 90% throttle.
for fixed wing users it now offers direct serial RX and telemetrie support, for now for SBUS and Sport, Graupner SumD and HOTT, Multiplex SRXL and Sensorbus and TBS CROSSFIRE. simply connect the signal to the signal input pin, and the telemetry bus to the TLM pin. it will do autodetect.
its features:
- 32-bit ARM Cortex M4 MCU @80Mhz
- Telemetry capability (voltage, current, temperature, rpm)
- Over current protection (measures the current and reduces it to max 45A)
- Over temperature protection (reduces the max power if hotter then 100C)
- sinHybrid :: Sinwave/BackEMF Hybrid Commutation for smoother running.
- Dshot 2400 (Full resolution of 2000 steps takes only 6.5s)
- Supports all common Dshot commands like turtle mode, 3D mode and rotation direction change.
- Expanded adaptive auto timing (3,25-30 advance on each commutation)
- For Race Multicopters (32A continuous also with weak cooling)
- High max. RPM (500.000ERpm, 71.400Rpm with a 14Pole Motor)
- Small size (19 x 27 mm)
- Accurate RPM control (2000 steps using Dshot)
- No additional capacitor needed for 3-5S. Add a min. 220F min. 50V Cap for 6S usage!
- Very fast throttle response
- Linear throttle response
- Active freewheeling (low diode losses)
- Regenerative braking
- 3-6S LiPo
- Dshot 100-2400, Oneshot42, Oneshot125 and normal (25 – 500Hz) PWM auto detected.
- Supports FrSky Sbus, Graupner SumD, TBS CROSSFIRE and Multiplex SRXL
as well as the Telemetrys, S-Port, Graupner HOTT, TBS CROSSFIRE and Sensorbus
videos:
Finalglide
Always something new (Frame, FC, Esc's) (3 min 20 sec)
quadmovr
dcl quad los | astrox truexs proto f40III 2600kv 5x4.8x3 hqprop kiss esc proto fc proto 4s1550 95c (2 min 25 sec)
6S
movr5r1 f40pro proto 5.1x5 apc prop kiss esc proto kiss fc proto 6s1300 95c (1 min 47 sec)
to be continued...
Nov 03, 2017, 04:46 AM
Arctic
The new Kiss esc what a cracker it's going to be.
Nov 03, 2017, 05:00 AM
So these are also backwarts compatable with the "old" FC (V1.03)?
ordered! looking Forward to flying them.
Nov 03, 2017, 05:01 AM
29.- Euro for one esc? Are you serious?
Nov 03, 2017, 05:44 AM
Order placed... :-)
Nov 03, 2017, 06:36 AM
Yes, of course they are.
Nov 03, 2017, 06:42 AM
ronnw's Avatar
Can't wait to try out these with the new Kiss FC V2 when it's released Will be my next setup for the next two years just like the Kiss FC V1 and 24A ESCs have been for the past two years now. Nice work Flyduino Love that about Kiss components No need to keep buying components just for new features, simply updating FW gives you all the newest features that come out. Can't ask for anything better when things change so fast in the mini quad world...
Nov 03, 2017, 07:45 AM
You guys are awesome!
Nov 03, 2017, 08:51 AM
What is landing :O
So you did implement some sort of FOC after all I think this will really help with the quick sort of throttle changes we do
Nov 03, 2017, 09:20 AM
Is DShot 2400 next firmware update?
Nov 03, 2017, 11:36 AM
urico's Avatar
Im guessing its probably something the new Kiss FCv2 can do.
Nov 03, 2017, 11:51 AM
NoGuru's Avatar
Never flew Kiss but these look inviting.
Nov 03, 2017, 12:47 PM
When in doubt throttle out
zestyzsauce's Avatar
you've been missing out!
Nov 03, 2017, 05:15 PM
Subscribe join the LEGION!
DRONE LEGION's Avatar
Oh Shxxx...t theyre real!
Christmas will be epic!!!
User reports please, need to fill my piggy first...
Congrats guys, hope they will be a game changer once again....
Nov 03, 2017, 07:08 PM
AKA Alex Wolf
awolf78's Avatar
Great work Felix!
Placed an order, Chad's new frame needs some ESCs
New Product KISS FCv1 / Flyduino 32bit Flightcontroller flyduino Multirotor Drone Electronics 26852 Jan 01, 2019 09:03 PM
New Product KISS ESC 24A Race Edition / Flyduino 32bit ESC flyduino Multirotor Drone Electronics 4880 Dec 01, 2018 04:41 PM
New Product KISS ESC 30A 2-6S LiPo from Flyduino juuuut Multirotor Drone Electronics 489 Mar 18, 2018 11:59 AM
New Product Dshot - Digital Protocol for Flyduino KISS FCs and ESCs flyduino Multirotor Drone Electronics 400 Jan 16, 2018 08:11 PM
