Nov 02, 2017, 01:46 PM
Jeanskydive's Avatar
Build Log
Pushy Cat
Hello everyone, I build this little project from Quiet & Flight Electric Magazine plan,. all balsa concept 36 in., wing span, I use for is power-up a Typhoon 2W20/ 3,400kv with 6.5 X 5 Graupner speed prop with and 3 LiPo., 70 amps, and 800 watts, I use 3/4 oz. fiberglass and resine for is fuselage only, wing and tail cover-up with natural solartex with clear nitrate dope, building in progress more infos later.... Cheers
Nov 02, 2017, 02:38 PM
jumo004's Avatar
Man ! That's a good look'in plane !!
Nov 02, 2017, 03:07 PM
killickb
killickb's Avatar
Been flying mine for 10 years now, has been recovered twice. Has the most amazing speed range from slow to fast that I have ever had in a model. Easy to build, easy to launch, easy to fly yet has performance coming out of the yingyang.
Fantastic fun per $ quotient. Is also a natural design to do some "personal" changes to shapes/curves.
Nov 02, 2017, 03:15 PM
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
Originally Posted by Jeanskydive
Hello everyone, I build this little project from Queit & Flightb Magazine plan,. all balsa concept 36 in., wing span, I use for is power-up a Typhoon 2W20/3,400kv with 6.5 X 5 Graupner speed prop with and 4 LiPo.,I use 3/4 oz. fiberglass for is fuselage only, building in progress more infos later.... Cheers
I also have one that is close to ten years old, great flying airplane and simple to build.
Did you know there is an old thread over in Sport electric airplanes? Lots of great pictures and builds there.....
https://www.rcgroups.com/forums/show...4832-Pushy-Cat
Latest blog entry: RC Throw Gauge
Nov 02, 2017, 06:06 PM
Pushy Cat
Thank I looking for.......... Run is elevator wire servo into is right tail boom and start covering solartex on is stab.,fiberglass and resine done, nex covering is wing with solartex and fews coats with nitrate clear dope. Cheers
Nov 06, 2017, 01:33 AM
Pushy Cat
Hello , Pushy Cat at the paint shop!!................. color probability white and blue Cheers
Nov 07, 2017, 10:58 AM
Donate Platelets
Is the wing a flat plate or built up?
Nov 07, 2017, 01:24 PM
Hello Jim, Yes flat plate 1/4 balsa sheet......... blue color trim is nex. .Cheers
Nov 08, 2017, 07:04 AM
yel914's Avatar
Great looking plane, looks fast just sitting there! Looking forward to reports on the maiden.
Rick
Dec 07, 2017, 10:07 PM
Pushy Cat
Hello , received all electronic parts install fit just perfect , backup is batt., a bit to get is proper CG., and test curent with différent Graupner speed prop, with 5 X 5 speed prop come right on the Typhoon specs., in watts and amps., such 6oo watts and 60amps with 3 lipo with is Typhoon 2W20 3400kv., motor. Cheers
Pushy Cat motor test.... (0 min 46 sec)
Aug 23, 2018, 05:21 AM
Clive Henry Jones's Avatar
Hi Jean, just finishing mine off - have you flown the Pushycat yet?
With your power system it should scream!
Clive.
Aug 23, 2018, 10:48 AM
A man with too many toys
Interested to see how to launch that airplane.
It is a very attractive airplane - fantastic build!
Aug 24, 2018, 06:35 AM
Hi RC man - they are handlaunch. I have a small skeg on the bottom of mine around the CofG (as per the plan) to assist with this.
Mine hasn't flown yet but I also have a Radjet that is a handlaunched pusher. I haven't caught any of my fingers in the prop YET!
Clive.
Aug 25, 2018, 09:29 AM
Clive.
HelloClive.... Nice job Bravo.....Yess ...I use bungee assist ...easy way also to go.... Cheers....
Aug 29, 2018, 07:51 PM
killickb
killickb's Avatar
Many, many underhand launches on mine with never a hint of a prop strike or a wobbly launch. Sad to say that mine exploded in mid air due to flutter during what turned out to be it's terminal dive!
Pushy Cat Ron Laden Sport Planes 952 Dec 03, 2018 10:21 AM
Build Log Pushy cat rabidrue1 Vintage & Old-Timer Designs 246 Aug 25, 2017 06:20 AM
Discussion where can i get plans for aero cat or pushy cat?? Laz51 Foamies (Scratchbuilt) 1 Dec 21, 2008 10:46 PM
Question Pushy Cat JMBRAD Pusher Prop Jet Models 3 Mar 11, 2005 06:08 PM
Foam version of 'Pushy Cat' in latest Quiet & Electric Flight Int.? mikefulb Foamies (Kits) 0 Jan 11, 2005 11:31 PM
