Nov 02, 2017, 10:30 AM
Opinion please
Just bought a used .48 surpass on ebay that someone had cut the mount to fit a specific model the description says. I would like some opinions on if it looks like it will be fine or do I need to put things into another case that I have for this engine.
Nov 02, 2017, 10:54 AM
Whatever It Takes
Gary Cee's Avatar
Aside from being very ugly, in most cases, it should be OK to use with an appropriate mount system.
If you feel otherwise, load the other case.
Nov 02, 2017, 11:16 AM
I generally use Dave Brown glass filled mounts when I build a plane. That's what will be going tin my current build
Nov 02, 2017, 11:25 AM
Other than its appearance it will work fine IMO.
Nov 02, 2017, 11:43 AM
Ok I'll just go with it
Nov 03, 2017, 09:31 AM
vic welland's Avatar
Fly it.
Nov 08, 2017, 06:40 PM
If you have another case for this engine, why not use it? What the heck else are you gonna do with it? Use it as an ashtray?
Max
Nov 08, 2017, 06:58 PM
SeismicCWave's Avatar
Max
Changing crank case may be more trouble than it is worth. What happens is the engine is old and tired and needed all new cylinder liner and ring? One easy way to find out is to fly it and see if it behaves. If it runs good then it is worthwhile to take the time to replace the case. It is all about costs and benefits.
Nov 08, 2017, 08:44 PM
Well I got the engine in, and wow it needs a new exhaust valve, probably a new rod as I've never seen so much play. This engine was used, and used well. but for $40 I can't complain. I'll get a set of bearings from Noel and replace them, new valve and rod and run it.
Nov 08, 2017, 10:33 PM
The great Brutufier
With all those new parts, and since you have to virtually tear it apart completely to replace that rod, I'd say take that little bit of effort to use that new case as well....
Nov 09, 2017, 05:49 AM
Whatever It Takes
Gary Cee's Avatar
Sounds like a good plan. I like to use the parts till they don't have any more "go" left in them! Not sure what it is about Magnum/ASP exhaust valves. Better have a good look at the valve seat as well. At least, give it a good cleaning.
Nov 09, 2017, 11:11 AM
Engine man
dmrcflyr2's Avatar
I am curious as to what you found wrong with the exhaust valve? I assume when you say 'rod' you are referring to the push rod. What was wrong with it? Bent? I think $40 for an engine with a damaged crankcase and in need of two major components is not a very good deal at all.
Nov 09, 2017, 04:22 PM
No, I mean connecting rod. I believe the bronze bushing is worn rather well and the exhaust valve is worn rather well. It's had a lot of fuel ran through it but for another 30 or so bucks it should be back to normal again. I may just put the valve in it and run it. After cleaning, the connecting rod actually feels better than it did when I got the engine.
Discussion Desperate plea for help, 2 quadcopters fully built, neither will fly Six_Sigma Beginner Multirotor Drones 37 Apr 03, 2017 12:44 AM
Discussion Plea for unity Lightnin Life, The Universe, and Politics 9 Nov 11, 2016 08:44 PM
Discussion Graupner GR - 18 testimonials pleas? Nitro2go Multirotor Drone Talk 11 Oct 30, 2016 06:58 AM
Discussion Now the gun control pleas MtnGoat Life, The Universe, and Politics 49 Jul 29, 2016 07:44 AM
Discussion A plea to the community. Joexer Model Aircraft & Drone Advocacy 1 Dec 23, 2015 07:37 PM
