Efficient motors for solar-powered robot application - RC Groups
Nov 01, 2017, 01:04 PM
Hello! I am building a solar-powered autonomous robot, and now I am searching for the right motors. The robot will have a 20W solar panel and 5000mAh 6.6V LiFePo4 battery in the 2S2P configuration. I don't know the weight yet exactly, but the motors should be able to handle at least 5kg. The robot should have 4 big 15 - 20 cm wheels. Ideally, I would have each wheel driven independently by one motor, but two (left and right) motor configuration is also possible. I calculated, that it would need about 10W mechanical power to drive upwards on 45' slope with 1 km/h speed and 5 kg mass. So, in reality, it would need 15 - 20 W mechanical power at maximum. Each wheel has to have about 100 RPM and 0,7-0,9 Nm. Because of the low power solar panel, I need the most efficient motors available. I have looked at Maxon motors, but they are very pricey. Which kind of motors is more efficient DC or brushless? Is it better to use one motor for each wheel or 2 motors with mechanical power distribution? Are there such brushless motors that can be used without any gearbox at speed about 100 RPM? Which manufacturers could you recommend to look at?
Nov 01, 2017, 03:55 PM
just look at it smokin'
z-matrix's Avatar
Hello!
A stock CD rom motor is driven at 10 W (but can handle 30W easily) at about 4000 RPM speed, so you can use that as-is with proper gearing, you need to connect it to delta to get higher Kv (or preferably rewind) for 2s use originally they are 12V.
So you need a gearbox that gives 40:1 reduction ratio for this motor.
Direct drive might be possible but i have yet seen a motor that was made for a similar application, it would need to be a ring motor and have 360 teeth around similar to a cd motor stator's at ~573 mm diameter, or ~287 mm diameter and double the width and ~180 teeth.
Z
Nov 01, 2017, 04:27 PM
CreFrod
If you Google search "100 rpm motors" you will find many to do what you want. For traction installations a DC motor has much better stall torque characteristics than brushless.
Most are made in the Far East and are cheap enough but you would have to accept shipping cost and delivery times.
Nov 02, 2017, 09:16 AM
I am very interested in direct drive with brushless motors because of simplicity and robustness. But if low kv motors are very big, could you recommend me some low power brushless motors?
Nov 02, 2017, 11:47 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
I am very interested in direct drive with brushless motors ...
Then better use sensored brushless motors and, of course, sensored controller. Much better startup and low rpm control.
For highest efficiency you should rewind good motors, with as much copper in the slots as possible.
BTW you do know you are one an RC e-flight (sub)forum?
Propellers and wheels are very different beasts.
Current = torque Kv.
A prop needs little torque ('=' current) at low rpm, whereas a wheel needs plenty of torque (= current) at startup.
Why not (also) ask a robot forum, or www.endlessphere.com (e-traction)?
Vriendelijke groeten Ron
Nov 02, 2017, 01:19 PM
Thank you. But all the RC Brushless motors I've seen have very high Kv and power for my application. As I said I need no more than 5W power MAXIMUM pro motor. Is it technically possible to build (or find) brushless motors that have about 100 RPM at 5,4 kg*cm (0,54 N*m or 76 oz*in)?
Nov 02, 2017, 01:25 PM
Thank you. But all RC motors I've seen have very high Kv (and RPM) and are very powerful. I need about 5W out (mechanical) power at highest efficiency possible and 100 RPM AT 0,54 N*m (5,4 kg*cm, 76 oz*in) torque. Is it technically possible to build (or find) such motor?
Nov 02, 2017, 08:24 PM
z-matrix's Avatar
Stepper motors dude
they are 200 step / revolution for example, they are small and high torque without gearbox
Z
Nov 04, 2017, 02:56 PM
An itch?. Scratch build.
eflightray's Avatar
There are a couple of other RCGroup forums that may be worth looking in --
Robotics -- https://www.rcgroups.com/robotics-297/
Cars -- https://www.rcgroups.com/cars-45/ -- the 'Rock Crawlers' section may be useful owing to their low speed high power.
Nov 26, 2017, 09:52 AM
Just hypothetical if you wanted to play w large gear reduction, brushless motor
Putting forth an idea just to experiment with, if you used a brushless outrunner 60:1 gear drive 10.5mm motor drive gear 6000rpm needed 1000kv with 6 volts and to drive an 11 pound (5kg) load up an incline
I didn't check the physics on a slope but was thinking yet of how powerful an iflight ipower Q series 5208 multirotor would be
They are are really easy to rewind and being a hi kv like 1000kv would be an easy wind, the ones I ordered are 320kv stock
With a large gear reduction like 60:1 setting the esc brake would certainly hold the robot as long as you had power, then it might hold on a slope without power against 11 pounds on say a 30 degree slope
I have found the greatest most efficient use of power by not overshooting what I want, airplanes 2 to 3 # thrust with a 12" prop 110 to 200 watts with no more than about 6300 rpm and 650kv on 12v using LIFE or A123 packs
Not ignoring your mention of 20 watts, I just don't know or think you can drive that kind of load for 20 watts per motor, and you only want to use a 10 AH battery pack? With my 2.2 AH cells it would take 10 to make that pack. Maybe you've found a bigger better battery in LIFE/A123
My favorite wind that eliminates transits and doubles wire current spec to wind a motor, is the series-parallel or half parallel dLRK wye wind
Well I like to wind and experiment, test etc so much, I'd like to get some more motors to wind even now, interesting question, especially the thing of trying to get the most thrust for the least amount of power
Leonard
Careful! Efficiency governs maximum power a motor can handle Ron van Sommeren Electric Motor Design and Construction 2 Sep 24, 2015 10:37 AM
Discussion GWS SERVOS for ROBOTIC APPLICATION gws roger GWS (Grand Wing Servo) 0 May 01, 2012 09:21 PM
Discussion Ultra Efficient Low Watt Motor for Solar Powered Planes Wrend Electric Plane Talk 13 Oct 27, 2009 01:42 AM
High Amp/Efficient Connectors (small/light/etc.. for LMR applications) eye_rc_soar Electric Sailplanes 19 Dec 11, 2003 08:29 AM
