Slimline Boxer/SL 2000 replacement rollers - RC Groups
Nov 01, 2017, 07:17 AM
Rotten40851's Avatar
Does anyone know where I can get( Or have made) a set of replacement rollers for my Slimline Boxer fuel pump? I have the old rollers if anyone can make them for me out of Delrin. They are just 3 small pieces of Delrin tubing about 3/4 of an inch long. I'm sure someone with a lathe can make them. Thanks
__________________
Nov 01, 2017, 12:57 PM
SeismicCWave's Avatar
__________________
Your local machine shop. If you can post pictures and the "exact" dimensions maybe some one here can machine them for you. Without additional information it is pretty difficult.
Nov 01, 2017, 02:19 PM
Here they are, they are 20 cm long 13 cm outside diameter and 11 cm inside diameter
Nov 01, 2017, 02:28 PM
Shouldn't be too hard. Most competent machinist can whip them up. Have you checked with your local machinists?
Nov 01, 2017, 03:10 PM
Sorry, not to be an a$$ about it but why do you need them? The reason I am asking is really how accurate do you need them. Is the inside hole undersized for a tight fit? A loose fit? How about the outside diameter? What about the chamfer angle?
It is not quite as simple as just whipping them out on a lathe. Yes I have a lathe. Yes I can make them. Yes I did make one. However without knowing the rest of the information I cannot guarantee that they will work. No, I am not a professional machinist but I do make parts for my models when necessary. No I don't have the most accurate machine but I make do.
If you look at the picture I am most concern about the inside diameter. I have an 11 mm drill bit but that is way undersized. 11mm is .433" and the diameter of my bit is .431. Delrin will shrink a little after machining so the diameter had gotten even smaller. So I went to a 7/16" bit which is .4375". As you can see in the picture I am still not quite 11mm. So if you need a hole that is exactly 11mm you are out of luck. You can always use sand paper to open the hole diameter a bit and do a hand fit.
My suggestion is still to get yourself a local machinist so they can fit a set of rollers in your setup.
Nov 02, 2017, 05:08 AM
Seismic CWave, thanks for your help. The ID is really that not important I guess ,these rollers are for a Boxxer fuel pump, the OD is what is important as they all rotate around the output shaft of the electric motor squeezing the fuel through a silicone fuel line, If you would be so kind I would gladly compensate you for making me the pieces. I could send you the worn rollers and you can match them. Here is how they are laid out, with the shaft centered in the rollers.
Nov 02, 2017, 06:21 AM
I meant to say MM not CM
Nov 02, 2017, 12:09 PM
I will make a couple more when I get a chance. You may have to sand them to fit.
Nov 02, 2017, 02:16 PM
You are a true gentleman, Thank you very much
Nov 02, 2017, 04:20 PM
Done. PM me your mailing address and I will send them over.
Nov 03, 2017, 04:43 AM
PM Sent, Thank You Sir
Nov 03, 2017, 11:53 AM
Ok will send what I made to you.
Nov 10, 2017, 08:09 AM
http://www.slimlineproducts.com/sl20...kit-p/2005.htm
$18, and includes tubing
Nov 10, 2017, 10:28 AM
Originally Posted by 2ltime
What a great find. Thank you.
I wonder if John received the rollers I made for him.
Nov 14, 2017, 05:37 PM
http://www.rcuniverse.com/forum/begi...-products.html Read This Link, Slimline is no more
Help! SL-1 and SL-1A computermonkey Classic Pattern Flying 9 Feb 23, 2016 05:51 AM
Discussion Aerosport Products SL-1 and SL-1A pattern planes computermonkey Classic Pattern Flying 3 Jan 11, 2016 02:51 PM
Help! Slimline 2000 Fuel Pump Frank Hurd Engines 0 Oct 14, 2015 02:05 PM
Yippee! Oh boy, a new "Clown Air 2000" Twin From J.C Penny with 3 ch SL radio + Video modfly Micro Ready-to-Fly 46 Feb 21, 2011 09:25 AM
Discussion SL prop replacement? customminatures Micro Ready-to-Fly 5 Jan 15, 2007 03:08 PM
