Feb 20, 2018, 05:26 PM
Originally Posted by savall21
Sweet! How are you doing the lap counter?
There are a couple of iOS apps that I found for this, not sure about Android:
whoop laps (best for single car tracking) & RC timing (will track multiple cars of different colour, but fiddly to setup)
Aug 17, 2018, 09:59 PM
Just wondering if this car is still popular? Where is the cheapest place to get one these days?
Aug 17, 2018, 10:51 PM
Yep, whole thread on them https://www.rcgroups.com/forums/show...55-Wltoys-1-28
Feb 17, 2019, 05:38 PM
wltoys k989 it does not go straight
Hi everyone.
If the wltoys k989 takes a hit in the front wheels it does not go straight on straight. I think it depends on the poor quality of the steering guard. Does anyone have a good steering guard to advise me?
Feb 18, 2019, 12:58 AM
Low budget fun
Beaver_XT's Avatar
Servo saver can be a bit wonky if the crash is too hard. You can re-align it later.
But if not you can DIY a guard using either plastic or carbon fibre sheet.
Edit: This will also help.
https://hobbyking.com/en_us/mini-q-s...de-wheels.html
Feb 28, 2019, 07:22 PM
Thank you Beaver.
another question: I would like to adjust the convergence of the front wheels of my k989. Can you tell me where I can find an adjustable tie rod that can be suitable?
Dec 30, 2020, 03:22 AM
Has anyone noticed that the "New" WlToys K989 have a different color servo horn and differential? I've noticed from the newer videos of someone unboxing it and it seems that you can't adjust the steering angle anymore. Can someone with this "new" batch confirm it?
Jan 29, 2021, 04:26 PM
forevernoob
friedartichoke's Avatar
Yep, I got mine today and it has the new servo horn. It has a larger hole at the top so I guess it can still be adjusted but the stock screw is just too small. I'll try to fill it with some epoxy or something
Feb 22, 2021, 06:04 PM
Protocol ??
I have the k969 model. Does anyone know what protocol it uses to bind it with my Radiomaster tx16s transmitter?
Feb 22, 2021, 09:54 PM
Temporal Flux's Avatar
My K989 uses the V2x2 protocol, subtype: JXD506. It should be the same for the K969.
It is not unheard of for WLToys to change the protocol though. They've done it before, even between different production runs of the same models.
Jun 07, 2021, 06:05 AM
pumuklis's Avatar
What is the governance of the model like?
Are there end positions right and left?
More jobs?
Or is governance proportionate? How many degrees do I turn on the steering wheel, how many degrees does the wheel turn?
Jun 14, 2021, 12:18 PM
I just superglued mine in works good so far
Jun 14, 2021, 12:21 PM
New diffs are also pretty bad. Instead of bushing they went with full thickness shaft. Stiff af and need sanding or something. I gave up and run them as locked diffs at the rear on my cars.
Mini-Review Hubsan X4 Pro FPV Full Review - [UnBox, Inspection, Setup, Flight Test, Pros & Cons] rc808hawaii Multirotor Drone Talk 24 Mar 09, 2017 12:32 AM
Mini-Review Walkera F210 Race Drone Review - [UnBox, Inspection, Setup, Flight Test, Pros & Cons] rc808hawaii Multirotor Drone Talk 5 Mar 29, 2016 02:26 AM
Mini-Review FQ777 954 FPV Nano Review [Unbox, Inspection, Setup, Flight Test, Pros & Cons] rc808hawaii Mini Multirotor Drones 30 Mar 14, 2016 05:15 PM
Mini-Review XinLin X118 (Mini CX-20) FPV QuadCopter Review - [Inspection, Flight Test, Pros&Cons] rc808hawaii Mini Multirotor Drones 11 Feb 11, 2016 12:23 PM
Mini-Review Walkera Runner 250 Complete Modular Race Quad In-Depth Review, Flight Test, Pros&Cons rc808hawaii Multirotor Drone Talk 1 Aug 10, 2015 05:06 PM
