Phoenix 8 New Day - RC Groups
Oct 31, 2017, 04:29 PM
PhoenixFlyer
PhoenixFlyer's Avatar
Phoenix 8 New Day
I have been here before, same subject. Now a little older, in colder climate, skills are still here, fire in the belly keeps getting lower. No problem. I have been watching build threads on here, learning new methods, and thinking about building again, our favorite models. This fuselage is 40 years old, no cracks or spider webs, it will be fine.
Oct 31, 2017, 04:55 PM
Formerly ReelDoc
Jim Johns's Avatar
Love the Aero Composites label in the 4th photo, Vince. Dave Scully's kits were outstanding for their time. I built a couple of his Tipo 750s back in the day.
Good luck finding a new color scheme - it's one of the hardest things for me. I would suggest adding a darker color for contrast. Speaking only for myself, I NEED excellent contrast these days - my old eyes aren't what they used to be.
Jim
Oct 31, 2017, 06:03 PM
PhoenixFlyer
Hi Jim. Good idea on color. Thinking of engine upright. Be first time in a Phoenix. No pipe. Check out this P-7.
Vince
Oct 31, 2017, 08:54 PM
If you come to South Florida give me a shout. I will be here.
Oct 31, 2017, 11:23 PM
Formerly ReelDoc
Jim Johns's Avatar
Vince
That's a first for me. I've never seen a Phoenix with pipe through the canopy before, although I did that to a Deception once.
Jim
Nov 01, 2017, 12:14 AM
AMA 2680
peeldog1's Avatar
Well Vince,
Since you followed mine, I'll follow yours. May pick up a new tip or two.
Is that fiberglass epoxy or polyester?
Ed
Nov 01, 2017, 12:19 AM
CPA #100
flyonenow's Avatar
Looking forward to seeing what you come up with Vince.
Paul
Nov 01, 2017, 07:28 AM
PhoenixFlyer
Ed. Epoxy, although most P-6's I did from that era, were polyester. Good ridgity at the empennage.
Pix, last TT I had, "would've-should've-could've" here. The blue one.
Paul, I am still figuring, especially the paint job. I have the other P-8 in Ohio, get that in January. Peeldog. I like your builds, every time I would look at your P-8, it would get me going.
V
Nov 01, 2017, 11:36 AM
Side mounted engine the only way to go.
Muffler or pipe under the wing...plus all the fuel goop!
Nov 02, 2017, 02:56 PM
PhoenixFlyer
Cut out center, R12 will protrude a little.
Nov 04, 2017, 05:03 AM
PhoenixFlyer
I am going to be a little slow on posts here, too much "stuff" on my plate right now. Slow meaning ongoing construction.
V
Nov 05, 2017, 02:52 AM
PhoenixFlyer
Bump
Nov 05, 2017, 07:23 AM
I’m watching closely. I’ve never built a fiberglass/foam airplane yet. Only built up stuff. Currently framing up an Astrohog. I’d like to get into this.
Nov 05, 2017, 07:28 PM
I like it!
Nov 06, 2017, 12:15 PM
PhoenixFlyer
I will be here for couple days, decided to get on with unwrapping 40 year old balsa. The metal here has the pivot point on the left side, allowing me to
get degree needed for cutting sheet balsa and film if used. Always cut with the grain. Pictures also attached of tips goal. This is from one of myP-6 builds,
template of ply sandwiched which will make the tips, both matched after carving. More on that later. As you can see, I will be working off of
glass for all cutting and sheeting the wing and stab halfs.
V
Discussion Diesel UAV Record 2-Day Flight Cut Short by 8 Days 9XTremist Model Aircraft & Drone Advocacy 0 Jan 07, 2017 02:19 AM
Alert New Gecko G540 (Revision 8 Model) $1, No Reserve, 5 Day Auction Aurora9 CAD/CAM 0 Feb 23, 2013 06:04 PM
Contest 2-Day F3F race at Weldon 8/25-8/26 seaspb Multi Task F3X 4 Apr 20, 2012 05:37 PM
Data Top Day Of Week for New Threads (GMT -8:00) Pacific Time (US & Canada) willhaney Site Chat 0 Sep 18, 2008 02:10 AM
