Tamiya 1/16 US M1A2 Abrams Full Option Kit
The new US M1A2 Abrams Full Option Kit from Tamiya is a functional work of art; this modern tank has been recreated down to the most finite detail.
The Abrams in All Her Glory
The 1/16 US M1A2 Abrams Full Option Kit is one of the most detailed tanks to come out of the Tamiya camp. It features a DMD T-08 multi-function unit for realistic movement, sound, and lighting, as well as a GFS (Gun Fire Simulator) unit and infrared LED unit for the detection and emission of infrared beams - perfect for organized tank battles. An extreme level of detail has been added to the Tamiya Abrams, including photo etched parts, full torsion suspension, and fine detail rendering throughout.
Powering the Abrams is a pair of 540-sized brushed motors, a 130 size turret rotation motor, and 130 size recoil motor. The Tamiya 1/16 US M1A2 Abrams Full Option Kit retails for $1059 and is scheduled for delivery in early November 2017.
CLICK HERE for more info on the new Tamiya 1/16 US M1A2 Abrams Full Option Kit
Features:
  • 1/16 scale plastic model assembly kit of the M1A2 Abrams
  • 540-size motor for impressive mobility
  • Expertly recreated flat turret, hull armor, and anti-slip surfaces on exterior
  • Tough duralumin chassis with metal parts for drive sprockets, idler wheels, suspension parts, and more
  • Durable pre-assembled resin double-pin tracks with metal pins and rubber pads
  • Aluminum barrel main gun can elevate and depress with a servo and Type 130 motor
  • Multi-Function unit with turret and vehicle control unit—turret rotation, gun elevation
  • Realistic sound and light effects (head and tail lights, barrel flash)
  • Photo etched engine deck and turret basket parts
Oct 31, 2017, 12:54 PM
Mmm, tugs...
patmat2350's Avatar
want...
Oct 31, 2017, 12:59 PM
Mmm, tugs...
patmat2350's Avatar
There is also a "display only" version, for less than half the cost... anyone have a clue whether that would have the same tracks as the R/C version?
https://www.towerhobbies.com/cgi-bin...&I=LXGYJG&P=ML
Edit: Possible answer- TamiyaUSA has a whole list of spare parts for R/C: https://www.tamiyausa.com/product/rc...1#.Wfi8efkrKHs
MUCH appears to be different...
Oct 31, 2017, 09:46 PM
it appears the serious armor modelers are not especially impressed with this kit, even the static one that sells for almost $600 (!!!)
http://armorama.com/modules.php?op=m...iew&artid=7549
Oct 31, 2017, 09:52 PM
Matt Gunn's Avatar
They are complaining about the price of the static kit, not the full option rc version. I agree. $600 for a static is a little up there.
Nov 02, 2017, 06:37 PM
C4ISTAR's Avatar
Visit the AAF Museum, Danville VA, online, for the best USA Tamiya rc Abrams’ price, $900.00 USD plus UPS charge.
For the static Tamiya Abrams’ the cost is $345.00 USD plus UPS delivery charge.
I have an rc Abrams kit on the way FYI, the kit static and rc kit tracks are identical. The main kit difference is the expensive rc electronic package is not included with the static Abrams kit.
FYI: The first USA shipment of the Tamiya rc Abrams sold out in about two days at the AAF Museum and should continue to be a very popular rc kit. The reviews are outstanding for the 1/16 scale Tamiya rc Abrams, as recently viewed at the better 1/16 scale rc tank oriented Facebook Group Pages and at the dedicated 1/16 scale rc tank forums
Dec 02, 2017, 06:47 PM
Bought one, built it. Typical Tamiya. Painted it in OIF colors and lettered with Desert Rogues markings. Awesome tank! If you are on the fence about one...GET IT!
Dec 09, 2017, 01:41 AM
C4ISTAR's Avatar
Tamiya 1/16 US Abrams IR RC Tusk II Tank Build; Maybe
Will start the Tusk II build after the Holidays and have collected all the after market parts or keep it IOF (just depends on it the Tusk II kit test fits well).
Happy Holidays, John
Dec 11, 2017, 08:33 PM
Other then a radio, and (building stuff like glue and paint) is there any thing else needed for this to be IR war ready?
Dec 11, 2017, 10:00 PM
C4ISTAR's Avatar
Yes. You’ll need a Tamiya Battle Unit (TBU).
Tip: Visit the AAF Museum online for the best USA Tamiya price for the kit, TBU, tank battery and a Futaba 4 channel rc System plus a left stick spring return kit.
https://shop.aaftankmuseum.com/searc...show=10&page=2
Recap; what you need:
1. Abrams kit.
2. Recommend a Skysport 2.4 Four Channel System, or I like and use the 4 channel Futaba FM Ground Radio for easier setup and reliable operation for activating all the IR and rc features for Tamiya’s modern rc tanks.
3. Tamiya Battle Unit, tank battery charger and tank 7.2 battery.
4. Glue and paint per the Tamiya Abrams Instructions.
5. If you use a Futaba System, you will need a spring loaded left stick return kit (ratchet stick does not work all that well with RC tanks). The museum may have the kit or they can tell you where to buy it. Simple to install.
Jan 26, 2018, 02:34 PM
Milviz
Hi C4ISTAR,
Where did you source the 1/16 scale Tusk II aftermarket stuff?
Jan 26, 2018, 08:15 PM
C4ISTAR's Avatar
Originally Posted by Milviz
Hi C4ISTAR,
dklmrc@gmail.com
DKLM RC: Contact Carson via email, the 1/16 Tusk II kit is not shown on the DKLM web site right now. I used the Tamiya 1/35 Abrams Tusk II model kit instructions, down loaded at Tamiya USA, plastic models, for my assembly guide. DKLM is a reliable vendor and uses PayPal. The Tusk II kit works for the the HL Abrams rc RTR tank too.
John
Jan 26, 2018, 11:50 PM
Milviz
Thanks!
Jan 30, 2018, 08:49 PM
Milviz
Off on vacation till the end of February... DARN!
Any other aftermarket items you can recommend? (either heng long or Tamiya)... I've looked but not sure what to look for...
Feb 06, 2018, 03:19 PM
C4ISTAR's Avatar
Sure!
1. Value Gear Resin Tarps 1/16 Scale buy on eBay.
2. Spec Op 1/16 Scale Modern Storage Gear order at
spectre29202@yahoo.com
or msg on FB: https://www.facebook.com/andy.meyers.39
3. Visit this DKLM RC web page for more parts:
https://www.dklmrc.com/M1_Abrams/cat...4_3329687.aspx
4. For the RTR HL Abrams M1A2, an adjustable idler system:
http://etoarmor.com/?product_cat=hen...ystems&paged=4
5. Modern US ARMY Tanker 1/15 (I use it as a half figure plus a sneak peek for the Tamiya Abrams build):
https://www.ebay.com/itm/Verlinden-1...IAAOSwqbxaIFTv
Video 1/16 Heng Long General Dynamics Land Systems M1A2 Abrams with Clark TK-22 test multiflyer2 RC Tanks 0 Apr 30, 2016 02:16 PM
Discussion Abrams M1A2 1/16 scale///Help Bob Platz RC Tanks 15 Dec 20, 2014 10:26 AM
Discussion Hobby engine Abrams 1/16 scale M1A2 Bob Platz RC Tanks 4 Apr 05, 2014 11:25 AM
Video HE M1A2 Abrams 1:16 julescrafter RC Tanks 4 Mar 01, 2014 06:10 PM
