HobbyWing XRotor FPV Racing Power Systems - RC Groups
Available through Hobbyking, these complete power systems come with props, hardware, motors, and ESC's.
Available Through Hobbyking
The HobbyWing XRotor combo is a turn-key power system for multirotors, and is available in multiple configurations. Designed to power racing and freestyle quads, the XRotor combos feature proven HobbyWing reliability, excellent responsiveness,
Here's what Hobbyking says about the XRotor packages: Designed for competition level FPV drones, this fantastic racing power system is remarkably small and lightweight. The quality operating components ensure less heat and higher efficiency. The FPV power system also features 3-in-1 drive IC and American Fairchild MOSFETs for a more rapid response while flying.
Weighing only 6g, the XRotor Micro comes with original BLHeli_S firmware designed specifically for competition FPV drones. The XRotor system is compatible with Oneshot125 (125-250Ás) high-speed throttle signals, Oneshot42 (41.4-83.3Ás) and Multishot (5-25Ás) super high speed throttle signals. The firmware also supports regular PWM (1000-2000Ás) throttle signals. Users can upgrade their firmware via the ESC signal cable and program up to four ESCs simultaneously.
Enjoy smooth throttle response and silent operation thanks to the ESC firmware with hardware-generated motor pwm. Using damped light for regenerative braking, the XRotor motor has fast motor retardation and active freewheeling. The twisted-pair throttle signal cable reduces the interference caused by signal transmission, increasing flight stability and reliability for multi-rotor drones.
CLICK HERE for more info on the HobbyWing XRotor combos.
Available Combos:
  • A, Xrotor-Micro-35A, XRotor-2405-1800KV
  • B, Xrotor-Micro-30A, XRotor-2405-2550KV
  • C, Xrotor-Micro-30A, XRotor-2405-2600KV
  • D, Xrotor-Micro-30A, XRotor-2405-2850KV
Nov 01, 2017, 02:33 AM
1800kv variant
Id like the 1800kv for an endurance build, but i cant find it listed on hobbyking. Are you sure theyre selling it?
Nov 01, 2017, 07:21 AM
RCGroups Editor
Matt Gunn's Avatar
If you don't see that version at HK, you can go straight to HobbyWing for it.
Dec 10, 2017, 03:29 PM
Deserteagle's Avatar
Hobbywingdirect.com has all of the packages if anyone lives in the US.
Latest blog entry: LOL I love it when I'm right
Question What is the maximum power cable length for hobbywing xrotor pro 80a esc? globalakawnt Multirotor Drone Talk 0 May 23, 2017 10:07 AM
Discussion HobbyWing XRotor 2205/2300kv + XRotor Micro 30A BLHeli_s DShot600 ESCs Datos Multirotor Drone Electronics 6 Apr 26, 2017 05:08 AM
Discussion Hobbywing XRotor FPV Racing Power System nluvwithxlr8in Multirotor Drone Electronics 0 Dec 06, 2016 07:31 PM
Discussion KDE Direct: XF Multi-Rotor Power System Kit For FPV Racing (under construction) RaymondM FPV Racing 16 May 05, 2016 02:55 PM
Discussion Hobbywing 40a FlyFun vs Hobbywing 40a Xrotor bostonkiter Multirotor Drone Electronics 0 Jul 01, 2015 06:21 PM
