Oct 31, 2017, 11:09 AM
mr1
mr1
What I think the EV200 will have:
1. Yes. Why should there be another reason for 2 antennas per receiver?
2. Sure, I think more than 32degree
3. Yes, for $399 I would expect that http://www.eachine.com/Eachine-EV200...tml?lang=en-GB
4. I really need that but I do not see any SD card slot on the pictures, so I hope, yes.
5. Maybe external, like EV100
If this was an investigation for marketing what new goggles should have, I tell you what I would like to have:
-DVR with auto record
-FOV 40-45 at 4:3
-4:3 display with 800x600 resolution or higher
-price < $200
-not sure about head tracking: I would use it but I do not know many people that use head tracking.
-LEDs in front are useless for me
I know, large FOV at low price is hard to built because of the optics. Depends on the price. At high price I would expect HD display at large FOV.
For racing, 4:3 is much more practial because you need vertical FOV much more than in aerial view.
The fan slots on top look really cool. Remembers me on https://upload.wikimedia.org/wikiped...and_Resort.jpg
For sure I would like to test one! I have been waiting for a small cheap FPV goggle for years! I built large goggles with 5" screen and fresnel-lens, even before they were on the market. The EV100 has too small FOV for me.
For the people that posted before: I would feel a little kidded
Oct 31, 2017, 11:25 AM
Features of this googles:
1. 32 degree FOV
2. Quad diversity
3. 4:3 display 800x600 resolution
4. DVR
5. HDMI in
6. Focus and IPD adjustment
7. Faceplate fan
8. Included 1000mah battery
Oct 31, 2017, 11:33 AM
Great idea for an early marketing campaign. Not only will this generate interest but you can figure out what to call the antenna feature. I like it.
Here is what I hope this goggle has:
• Screenless DLP display similar to the Avegant Glyph (about time) with an optical adjustment system that includes IPD and focal length.
• 1280 x 720 display
• 40 degree FOV
• Less than 30ms latency
• Two sets of antenna diversity combined by actual diversity. Possible names: “Dual Antenna-Diversity Diversity (DADD)” or “Quaversity” or “Bi-Antenna Diversity (BAD)”.
• Built in DVR
• HDMI input accepting up to 1080p
• 3D compatible both through HDMI and diversity units
• Dedicated DVR joystick
As well as everything else the EV100 has:
• Composite AV in and out
• Auto channel search
• Racing mode
• Debug mode
• Fan
• Low battery alert
• External power bank and firmware upgrade port
• OSD
• Detachable faceplate with easy to replace foam
• Headphone jack
• Menu joystick
Bonus suggestion:
• Different faceplates for different face shapes.
• External VRx module support would make many happy. If the stock VRx is capable, I don’t care personally.
Oct 31, 2017, 12:15 PM
Now I don't want the EV100's anymore and I like how Eachine listens to customer input on their products in order to make improvements.
#1 - Features of the EV200D
  • $299 USD price tag on sale and regular $399 USD
  • Battery included
  • NTSC/PAL compatible
  • Dual diversity built-in to out perform Fatsharks
  • Adjustable 40-45 degree FOV
  • Built-in DVR
  • 3D support
  • 4:3 800x600 or 16:9 1280x720 display resolution
  • Built-in cooling fan to keep goggles from fogging up
  • Ability to use Eachine battery or your own 2S-4S LiPo battery
  • 720p video-out resolution
  • Adjustable IPD 55-70mm
  • 5W power consumption
  • Largest screen ever put in non-box style goggles
  • HDMI in and out
  • Race mode
  • OSD options
  • Higher quality face foam
  • Headphone jack
  • Head tracking
#2 - New feature suggestions
  • Thin, medium, and thick foam options for different faces
  • Voice alert when battery voltage is low on goggles and/or aircraft
  • Power On/Off button
  • Different colors and patterns on goggles like on FrSky transmitters
  • Modular receivers so users can use their preferred brand
  • Kit version with no receivers or battery included
  • 16:9 1920x1080 display resolution
  • 1080p video-out resolution
  • Adjustable 40-60 degree FOV
By the way, thank you for the t-shirt as well, Banggood!
Oct 31, 2017, 12:33 PM
  • Battery included
  • Built-in DVR
  • 3D support
  • HDMI in and out
  • Race mode
  • OSD options
  • Headphone jack
  • Head tracking
Oooooo, I like the adjustable FOV idea.
Oct 31, 2017, 12:37 PM
As a long time gamer, adjustable FOV's can make a big difference and increase personal performance.
Oct 31, 2017, 12:59 PM
mascaras's Avatar
1.Surmise the features of this goggles
• FOV increased (30 ~ 40)
• NTSC/PAL video format supported
• Adjustable Focal length
• Adjustable IPD
• Adjustable brightness & contrast
• DVR
• Built in OSD ( channel, band, battery )
• Built in FAN
• Dual Receiver Diversity with Antenna Diversity ( 4x antennas capable)
• Auto scan
• AV in/out
• Rechargeable battery with usb charging function
• Battery included
• Extra foam included
• Goggle Case/bag included
2.Think up the new features and suggestions :
• 16:9 & 4:3 display ratio ( switchable)
• 3D & Head Tracking (optional)
• Adjustable screen Color (not only brightness and contrast)
Oct 31, 2017, 01:38 PM
New goggles
Product specifications:
Freq 5.8GHz, 72 channel
Sensitivity <= -93 DB
Antenna: quad antenna, (2 reciever diversity)
Description
Brand Name : Eachine
Item Name : EV200D
Display
Resolution : 720*540
FOV : 35 diagonal
IPD : 58-68mm
Ratio : 4:3
Focal length adjusting: under 400 degree of myopia and hyporopia 150 degree
Specification
Frequency : 5.8G 5333Mhz-5945Mhz
Sensitivity : <=-93dB
Antenna Impedance : 50Ω
Antenna Gain : 3dBi
Antenna Connector : RP-SMA
Video Formate : NTSC/PAL
Support AV IN/OUT
Support Focal Length/Brightness/Contrast Adjustment
Suport Firmware Upgrading
Power Input : 7.4V
Low Voltage : 6.8V
Battery : 2S 7.4V 1000mAh
Features
Support AV Input and Output
Supports defogging fan
Supports OSD menu
Support External HDMI to AV Module
Support External DVR module
Frequency scanner
Oct 31, 2017, 04:50 PM
Eachine EV200D
Screens : Aspherical lens that will focus on 800x600 for 4:3 (or 854x480 for 16:9) screen with 38 degrees FOV. Yes, 4:3 and 16:9 will be switchable.
Receiver : Two slots,one diversity. Two of them will be SMA other two will be RP-SMA.
DVR: There will be DVR, so microSD slot is there too. You will be able to play DVR instantly through goggles (second black dongle, that one on side without arrow buttons, will allow you to go through DVR menu or overall goggles menu). Of course viewing and recording in both PAL/NTSC.
IPD and focal adjustments: Same as EV100 , 58 to 69mm. Of course focal length is adjustable too.
Inputs/Outputs: There will be audio jack for audio, also HDMI IN and USB port for power from powerbanks. There won't be any headtracker.
OSD: Known from EV100, views band, channel, frequency (or which racer), can be turned off.
Fan: Fan included. With on-off switch
Faceplate: That cut in middle allows to fit 3 point straps - from left to right side and through middle of head (like in EV800)
Brightness and contrast : Can be changed by second dongle (near arrows). Second dongle is used as mode changer too.
Battery : Powered by 2S battery that can be charged via USB. 2S 1400mAh.
Super-power hidden option: EV200D will have something changeable. Look at picture of black ones. Do you see that the middle curved part of goggles leaves blacker (more black) strip on that top part. Looks weird, unless... It looks like the middle curved strip of goggles (that whole curve with word "eachine" from left to right) will be just a cover for something under it. Then, having such big,stretched holes for antennas will have sense, cause holes are so big and stretched to gently take off that cover. Also, white plastic under that holes, another thing that suggest that "cover" thing. What's under it? Receiver bay? Additional ports? I bet that's receiver bay.
EDIT: If i'm right, that the whole curved middle thing is just a cover, then call me Mr.Holmes and gib me those beauties.
If not, add this thing to this goggles and hide there changeable receiver bay
Last edited by Shedgemedgen; Oct 31, 2017 at 05:17 PM. Reason: adding info, changing midsection for more understandable word.
Oct 31, 2017, 09:18 PM
800x600 resolution LCD screens
Brightness/contrast/color adjustment
FOV 38 degrees
DVR with multi-resolution recording up to 720p on MicroSD card
RGB LED light up front logo/pattern
2 way dual diversity modules, non-replaceable
On/off feature for antifog fan
Adjustable IPD improved over the EV100
USB for firmware updates
Fatshark compatible diopter slots
Fast autoscan with previous channel memory save
Favorite channel save slots
Auto on/off for screens with proximity sensor
OSD for channel/band/battery
HDMI input
3.5mm AV output
3.5mm headphone output
4:3 and 16:9 viewing selection
1000mAh battery with LED indicator and USB charging
Foam faceplate with low light leak
Circular polar + patch antennas included
Speaker for menu and battery feedback
$289.99 price
2.
Replaceable receiver modules
Head tracking
3D input from HDMI
Variable speed antifog fan based on humidity sensor
Optional hydro-dipped patterns instead of plain colors
Custom OSD configuration (colors, locations of text)
USB goggle configuration through special program via PC / android / iOS
Low battery warning through vibration feedback
Front camera with switching button
Oct 31, 2017, 10:14 PM
Mitchie's Avatar
Based on the lack of interest in this thread (Only 4 pages in 1 day based on two pictures), I don't think they will move forward on production
What do I think(hope) they'll have?
1 32deg minimum fov
2 dual diversity with 3D?(possibly optional in bay/s)
3 battery on the side....hate that! Put it in the middle please! It can't be that hard to design a decent battery holder (I was thinking just a neoprene sock would work very well!)
4 built in dvr(I hope)
5 reasonable price point please. I'd be very happy with modular design including single diversity and dvr for the $200ish price point. Second diversity setups could be added later for those who wanted it.
Suggested improvements
1 Put the battery in a neoprene sock at the middle in the back! (now just going to have to build one.....I think I know how)
2 Individual switches to power on and for the defogging fan.
3 2-3 different foam thicknesses of foam (suit more faces)
I got the EV100's and coming from the box stile goggles (VRD2's, then Pro's, then Goggles two) and found them to be good goggles for the price ($100). I would like it if they had done a little more testing in the areas we all know (cap, fw) and hope the new 200's get a little better. I'd love to try them!
Oct 31, 2017, 11:03 PM
TS Banggood RC's Avatar
OK, Eachine EV200D https://www.banggood.com/Eachine-EV2...ds=newArrivals HD Port in = HDMI
Oct 31, 2017, 11:09 PM
It's been listed on Banggood: https://www.banggood.com/Eachine-EV200D-1280720-5_8G-72CH-True-Diversity-FPV-Goggles-HD-Port-in-2D3D-Built-in-DVR-p-1220010.html
Here are the specifications:
Specification:
Item Name : EV200D
Frequency : 5.8GHZ
Debug frequency: 5300MHz
Frequency range: 5333-5945MHz
Audio and video: AV in/out
Brightness: adjustable
Contrast: adjustable
Pupil Distance adjusting: 56-72mm
Power input: 7.4v
Low voltage: 6.8v
Operation temperature: -10℃-40℃
Features:
FOV 42
Built-in DVR
USB power supply
Resolution 1280*720
7.4V battery with LED indicator
Aspect ratio 16:9/4:3,Default display is 16:9
Supported display mode: HD Port in 2D/3D; AV in 2D/3D
IPD adjuastable 56mm-72mm: wide range IPD adjustable,suitable for more pilots
Optional diopter lens,compatible with Fatshart diopter lens,200/400/600 degrees selectable(diopter lens not include)
Dual True diversity RX modules:True diversity RX module/Open source supported/Compatible with Fatshart OLED receiver
Package included:
1 x Set A or Set B
1 x 7.4v 1800mAh Battery
1 x USB Cable
1 x HD Port Conventor
1 x HD Port Cable
1 x 3.5mm AV Cable (one-in-three)
1 x Lens wiping cloth
1 x User Manual
Note: Set A is Eachine EV200D goggles only
Set B is Eachine EV200D goggles + 2*True diversity receivers
Oct 31, 2017, 11:12 PM
The activity of surmising the features end.
The suggestion activity keeps on and once Eachine catches them, we will send you a free sample
Oct 31, 2017, 11:13 PM
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Official Product Page
➡ The EV200D product page is up!!! 👍
New Product $3x FPV goggles?Eachine VR006 3 Inch 500*300 Mini FPV Goggles ----Free Review BGjim FPV Equipment 401 Jul 08, 2019 03:50 PM
New Product Eachine Goggles Two 5 Inches Raceband HD 1080p HDMI FPV Goggles Video Glass BG-Wilson FPV Equipment 589 Mar 25, 2019 03:32 PM
New Product Eachine Goggles One, 5" 5.8GHz 40CH 1920x1080 HDMI FPV Goggles FyreSG FPV Equipment 580 Oct 02, 2017 07:20 AM
