Good Motor for over 120+ MPH - RC Groups
Oct 30, 2017, 08:16 PM
What a good motor that I can use for my Wing Warrior E-Slayer 48" wing that will push it over 120 MPH and have unlimited vertical. Something that can handle 6S lipo and a 5x5 prop.
Nov 08, 2017, 11:07 PM
The 6 P principle works for me
elecfryer's Avatar
Well........looking at it from a numbers (rpm) point of view........
If at full throttle on the ground you have a (prop) pitch speed of 125 mph, 125 / .000947 (a constant) = 131,995.
131,995 / 5 (pitch of the prop) = 26,399 rpm
assuming you are running at about 70% efficiency (static, on the ground at full power on 6S lipo) the kv of the motor should be about 1700
if the loaded voltage at full power is 22.2V (3.7 volts per cell at full load) 26,399 / 70% = 37,712 and 37,712 / 22.2V = 1699 KV.
So, I think you are looking for a motor with a KV of about 1700 THAT CAN HANDLE THAT MUCH POWER.
I think you are looking at well over 1,000 watts.
Just a start of course. Hope it helps!
Michael
Nov 09, 2017, 10:35 AM
Thank you!
Nov 11, 2017, 09:09 AM
Ft Lauderdale
Number_6's Avatar
https://hobbyking.com/en_us/turnigy-...___store=en_us
Probably heavier motor than you want,
but I use this motor with 100 Amp ESC,
on 6s, for 142mph bursts with Grim Reaper,
pusher motor.
I got the idea from this:
http://rcfoamfighters.com/Models/FF-...-SuperNova.htm
Probably still the 'cheapest' way to go way past 100 mph.
I didn't reverse shaft, just made custom motor mount.
Nov 11, 2017, 11:50 PM
Thanks!
Discussion flip over on takeoff (motor, props and fc checked and good direction) gottx1 Multirotor Drone Electronics 3 Oct 16, 2016 09:41 AM
Discussion Looking for a good 120 mm / 12s setup bushong572 Electric Ducted Fan Jet Talk 13 Apr 15, 2016 08:04 AM
Discussion Looking for 120 mph and 30 lbs static thrust on a 100cc? engine... What prop? ChillPhatCat Engines 16 Jun 16, 2015 06:53 PM
Discussion looking for 120 mph motors fpvguy Foamies (Scratchbuilt) 4 Jan 31, 2012 06:11 PM
Discussion Good brushless motor/ESC combo for Corona 120? ViperR Electric Heli Talk 5 Dec 22, 2007 01:18 PM
