Oct 30, 2017, 01:02 PM
DIY large scale coaxial heli AND controls to new radio (FrSky Taranis X9D)
Hello everyone. My project involves converting a larger scale coaxial helicopter (much larger than the indoor sized ones) from 49 MHz controller to 2.4 GHz so there can be more servos and channels for brushed ESCs. The mechanics and controls are the same from the fun indoor coaxial rc helis with counter rotating propellers and a vertical lift propeller on the tail for forward and backward movement.
I'm keeping the same brushed motors that fit in their mounts inside the chassis and connecting them to 20 A brushed ESCs. Also adding a brushless ESC for a brushless motor for a prop mounted for horizontal thrust at the tail (pusher prop). The controller I'm planning on using is the FrSky Taranis X9D which with OpenTX I'm hoping will suit controls setup.
In the MIXER, I'm having a little trouble figuring out how to connect the motors to the correct channels while still maintaining the yaw channel controlling the bottom rotor. I'd like to have the two rotor ESCs connected to the same channel controls, but have the bottom rotor connected to the yaw channel as well. I'm wondering if it would be possible to put two PWM wires in parallel from different channels from the rx to essentially give the bottom rotor a subtrim+yaw control?
Thanks any help and input is apprciated
Nov 02, 2017, 12:20 PM
I've found a way to have the coaxial rotors have differential thrust with the OpenTX companion software. I just need to translate it from the computer software to a model on my X9D so I can use the programmed mixer in real life. So, I think I'll try to sync up transmitters using the miniUSB to USB cable. *added pictures to show companion software
Discussion Taranis X9D Plus Radio Controller foxtechtech Foxtech Hobby 1 May 17, 2017 03:22 AM
Help! Unable to Calibrate FrSky Taranis X9D+ Radio in Mission Planner Rrotz Radios 3 Feb 05, 2016 04:20 PM
Discussion Taranis x9d radio to control a car? orion33 Car Talk 13 Jan 05, 2016 08:23 AM
Help! Taranis x9d frsky with arris quad open flight cc3d can't set up radio rsheehan79 FPV Racing 1 Sep 18, 2015 05:34 AM
Discussion Taranis X9D Plus Radio + FrSky X8R marcel_cote Multirotor Drone Electronics 0 May 23, 2015 08:27 AM
