Oct 29, 2017, 07:42 PM
ZTW ESC and programming card
I have a ZTW 65A ESC and when I finish programming the ESC the motor gives two beeps. The instruction manual says there should be one beep. The motor does not run but the rudder servo works. Does anyone know how I can fix this? I have an E-flite P-47 and a DX8 G2.
Oct 30, 2017, 02:46 PM
Ohio AV8TOR's Avatar
This may not be it but several ZTW’s back I had to reverse the throttle servo at the transmitter. All was good then.
Nov 09, 2017, 03:08 AM
I fixed it but there's another problem. At low throttle the motor's rpm jumps a little, it isn't linear. The motor I'm using is supposed to be used with a 3s lipo but I'm using a 4s. The ZTW ESC isn't the original one that came with the plane.
Question Turnigy ESC Programming Card - will it work for HW SK ESCs? goshakv Racing Boats - Electric 4 Feb 14, 2017 02:26 PM
Discussion Do you program those new small blheli ESC like the old ones with programming card? FlyingPancake Multirotor Drone Power Systems 9 Jun 08, 2016 01:35 PM
Discussion Program ESC Card, 2 ESC's simultaneously doug47 Power Systems 6 Jan 29, 2016 05:14 PM
Help! ZTW programming card 732002 Power Systems 2 Jan 15, 2012 01:24 PM
