Solved - Spektrum DX9 "Expecting STRING" issue. SPM files attached - RC Groups
Oct 29, 2017, 04:34 PM
RNAF's Avatar
Help!
Dear all,
I have been having some troubles with my DX9 lately. Adding to that - before sending it for repair - I made a back up of all my models.
At the same time it gives the opportunity to re-name many models. Re-importing them does not seem to work.
I get "12: '' Expecting STRING"
Now I took some models from Spektrum's site and compared the code. But wasn't able to find major differences. Any idea what's wrong here? My DX9 doesn't have any models in it right now, except for a few that did import..
Reflex V2.spm imported
Mini Vapor.spm did not import
Cheers!
Oct 29, 2017, 04:45 PM
AndyKunz's Avatar
You are trying to import version 1.20 files into pre-1.20 radio. Update your radio to 1.20.
Andy
Oct 29, 2017, 05:03 PM
RNAF's Avatar
Hi Andy, I have upgraded to 1.20 earlier today. Any thoughts?
Oct 29, 2017, 05:11 PM
AndyKunz's Avatar
Don't have radio handy to see what line number it reports that on. Do you know? The line number is on the error message.
Andy
Oct 29, 2017, 05:18 PM
RNAF's Avatar
Hi Andy, it says "12:" otherwise no information. Is that the line I should look at?
Appreciate your responses!
Edit: thanks to your lines remark I went and took a very close look at each and every character on line 12 of the file. I found the culprit were the quotes. They were slightly slanted, ever so slightly you would always look over it unless you focused on it. I copied the character of another file that did import - problem solved. All models imported.
Oct 29, 2017, 06:11 PM
AndyKunz's Avatar
Yes.
Did you happen to open the file perchance before doing this? Or maybe download it into an editor?
It looks like the kind of change that an editor would do to match the local region quote character from the operating system.
Andy
Oct 29, 2017, 06:16 PM
RNAF's Avatar
Hi Andy,
Indeed, I opened it before, using Mac's standard text editor application.
Discussion Spektrum DX9 issue (spirals in to the ground) mvd1968 Radios 363 Mar 28, 2016 09:27 AM
Help! NEW Spektrum DX9 + AR9020 9-Channel DSMX + HABU 2 EDF THROTTLE ISSUES bgargas12 Electric Plane Talk 18 Dec 08, 2014 03:01 PM
Question Spektrum DX9 Throttle Cut Issue PajosFTW Radios 2 Sep 21, 2014 05:25 PM
Discussion Suspected Spektrum DX9 issue(nose dive) vivekrathour Radios 3 Mar 23, 2014 04:35 PM
Discussion Spektrum DX9 display issue harrry66 Radios 3 Oct 07, 2013 09:49 AM
