Question
Nitro Pick up
I'm almost done with my SPAD. Well, really I am done, but I can't get the fuel to the carb on this 51magnum motor. I can prime the carb with fuel and the motor runs, till it runs out of fuel. When I take the carb line off the motor and try to start it, no fuel comes out.
I have a 3 line fuel system. Filler, Pressure, and Carb. I can blow through the pressure line, and blow fuel out the carb line with no problem. I can plug 2 of the 3 lines and blow till I turn purple which I've done like 6 times, and I can't get air in, so I'm thinking, OK, no leaks. Any ideas? What else should I look for? Edit: Well I put in a new stopper with a 2 line system. Still the motor will not pull up fuel to the carb, but I can remove the pressure line from the muffler, and blow fuel through the carb line.. I'm going to remove the head and make sure it's seated well. Sheeeeeesh |
Hi Red... Just checked the needle valve. It was shut completely. I must have shut it when I pulled the motor apart to clean it, from when it nosed into a bean field last year. The motor had all kind of dirt in it.
The HSN was completely closed. I've opened her up 3.5 turns. Maybe that will work. Stay tuned |
Well, it flys...
![]() For what ever reason though, I cannot for the life of me run the motor at factory settings with regard to needle valve settings. I actually had to turn the motor upside down, because the fuel tank was a bit lower than the carb intake opening. I haven't had a chance yet to fly it much and tune the motor, but it flys... ![]() It's Alive ! It's Alive ! |
Thread Tools | |
Similar Threads | |||||
Discussion | Older Pick up truck vs. Newer Pick up truck.......Head on at 6o mph . | rockyboy2 | Life, The Universe, and Politics | 21 | Jun 05, 2017 10:56 AM |
Help! | OS Max RG refuses to start Anyone familiar with a O.S Max RG nitro motor? Just picked | Camscam204 | Nitro and Glow Power Cars | 49 | Oct 04, 2016 03:41 PM |
Discussion | Rudder pick up vs. Transom pick up | nhrider19 | Racing Boats - Electric | 7 | Jun 23, 2013 01:29 PM |
Discussion | Can you pick up spare parts from nitro planes? | lovetoflyjets | Electric Ducted Fan Jet Talk | 0 | Apr 27, 2011 10:01 PM |
jest picked up my new nf nitro bike from cnr today. | kidz12003 | Motorcycles | 6 | Jul 27, 2004 05:35 PM |
