GEPRC LX One Leopard LX4, LX5, LX6 - Lighter, One-Piece Leopard Redesign - RC Groups
Oct 28, 2017, 11:49 PM
New Product
GEPRC LX One Leopard LX4 LX5 L6: https://www.banggood.com/GEPRC-GEP-LX-ONE-Leopard-LX4-LX5-LX6-195mm-220mm-255mm-FPV-Racing-Drone-4mm-Arm-p-1218479.html
GEPRC has redesigned their standard size Leopard lineup, optimizing weight and durability. For one, the frame now features a single baseplate. Also, gone are the carbon fiber camera mounting plates and bottom aluminum plate.
Summary:
The leopard, natural predators, running at a staggering rate.
This is the GEP-LX, also called ‘Leopard’, there are three kinds of specifications respectively, 4 inch (wheelbase 195mm), 5 inch (wheelbase 220mm), 6 inch(wheelbase 255mm). The fuselage low center of gravity design.
It is equipped with a 3k ultralight carbon board CNC fine machining, the airframe aluminum #7075 fuselage, the fuselage side board is integrated, the perfect protection lens has other electronic equipment.
We also equipped with A piece of PDB, take BEC output 5V 3A and 12V 0.5A. The frame all adopt the YFS screws, 12.9 magnitude.
Description:
Brand: GEPRC
Name: GEP LX ONE Leopard ONE
Material: 3K carbon fiber & #7075 aviation aluminum
PDB: 5V 3A & 12V 0.5A BEC
Screws: YFS 12.9
Thickness of integrated frame arm & bottom board: 4mm
Thickness of side plate: 2mm
Thickness of other plates: 1.5mm
Wheel base:
LX4: 195mm
LX5: 220mm
LX6: 255mm
Weight:
LX4: 99g
LX5: 104g
LX6: 114g
Features:
1. Aviation aluminum #7075 high-precision CNC fuselage, very strong resistance to blast.
2. 3K high strength carbon board to ensure that the frame is strong.
3. An aluminum alloy structure, binding the four machine arm will not shift
4. “True X” Structure. Suitable for competition and Freestyle fancy flying.
5. Reasonable gopro, runcam position, convenient video.
6. 13.5 mm wide, 4 mm thick arm design, small wind resistance coefficient.
7. 5 inch wheelbase 220 mm, 4 inch wheelbase 195 mm, 6 inch wheelbase 255 mm, have wider air through.
8. The YFS screws, 12.9 level of hardness.
9. The motor position widened, home is not easy to hit the motor.
10. The camera is adjustable, 0 to 60 degrees.
11. With the kits: a piece of PDB panels, integrated XT60, BEC (5/12v output).
Package included:
1 x GEP LX ONE Leopard FPV Racing Frame
1 x PDB 5V & 12V
2 x battery strap
Nov 14, 2017, 08:51 PM
I have the LSX5 right now and love it. For reference, it weighs 134.81g on my calibrated scale without the battery plate and with the plate it weighs 146.49g. I'm probably going to get the 6 inch version of this one piece. Are the weights accurate though? Is the 6inch really 114g? With or without the battery plate? Because the original frames had inaccurate weight advertisement. Also, are the side camera plate mounting holes still the same distance from the front of the rollcage offering the same amount of protection as the original?
New Product GEPRC GEP-LX Leopard FPV Racer Thread nitbeat Mini Multirotor Drones 187 Today 06:05 PM
Build Log GEPRC LX5 "Leopard" (F40 III's, KISS build) Zytrahus Mini Multirotor Drones 2 Jul 30, 2017 03:03 AM
Build Log GEPRC LX5 "Leopard" (F60's, BrainFPV RE1) Zytrahus Mini Multirotor Drones 13 Jul 06, 2017 10:42 PM
Build Log An Ablazing's Build Log and Review of the LX5 Leopard Courtesy of GEPRC! WIP... Ablazing Mini Multirotor Drones 1 Mar 22, 2017 11:53 PM
