This thread is privately moderated by LemonC, who may elect to delete unwanted replies.
Oct 27, 2017, 01:27 PM
LemonC's Avatar
Omnibus F3 NANO STM32F303 2-4S Flight Controller 20*20mm 3.7g Built-in 5V 3A BEC OSD
https://www.banggood.com/Omnibus-F3-...rmmds=category
Specification:
Item name: Omnibus F3 Nano flight controller
Mount holes: 20mm*20mm, M2.5
Weight: 3.7g
CPU: STM32F303CCT6
Sensor: SPI Sensor MPU6000
Power supply: 2-4S
Firmware version: Betaflight 3.2.0
Target: betaflight_3.X.X_OMNIBUS
Without barometer
Receiver: SBUS/IBUS/DSMX/PPM ETC
Suitable for ≤150mm frame kit, especially for 130mm frame kit
Features:
-Support programmable LED_STRIP (turn off transponder before using)
-Support the newest DSHOT1200, PROSHOT ESC
-Support BLheli suite
-Built-in OSD
-Built-in 5V/3A BEC
-Bulit-in LC filter
-Buzzer solder pin
-Built-in voltage detection, alarm
-Reserved current sensor solder pin
-Reserved IIC solder pin
Receiver configuration:
DSM, SBUS receiver input, please configure RX3 as input interface
Package inlcuded:
1* Omnibus F3 Nano flight controller
**i havent found any reviews on rcgroups about this FC, yeah its F3 but should be good for me.*** i hope i have a positive experience with it.
Just got one of these in yesterday finally. i went with it bc it has 3a 5v onboard, F3 with lot of accessable pads, Im gonna run it with a xsr-m, F3 should make the telemetry a bit less of a headache hopefully. Im putting it in my GepRC Sparrow frame - got my replacement arms the other day. I also got a Runcam Sparrow micro 16x9 fpv cam to throw in the mix. Waiting on DTX03 from Banggood US warehouse, should arrive any day now. why is their US warehouse shipping running so slow ?
Got it wired mostly last night. Im using a Super Colony 20a 4in1 esc from readytoflyquads , which has vbat output via it's mini-connector, had to depin one end of esc's connector wire to a 6pin to connect with the F3 nano, which will take in vbat - which is pretty convenient for my purposes.
I like the sparrow frame but it broke almost right away which was a major bummer. In hindsight i wish i would have bought an Airblade eclair 3in (i like the DTX03 pod you can add to the airblade eclair), but oh well. next time.
Currently got some 1407 3200kv RCX motors and dalprop 3in triblade bullnose props setup on it.
Pics soon.
Oct 30, 2017, 03:05 PM
LemonC's Avatar
Flies. Fleas. Two packs so far. Tune a lil after work today hopefully. Im getting Audio noise in my DVR Footage which i hope i can resolve, the footage itself is nice and clean!
New Build: GepRC Sparrow Stretch Runcam micro Sparrow DTX03 (3 min 43 sec)
Nov 02, 2017, 02:00 PM
LemonC's Avatar
GEPRC Sparrow stretch (3 min 28 sec)
i really like this setup so far, but i need to add a linear antenna to the DTX03 soon.
Nov 15, 2017, 01:13 PM
chrys_burge's Avatar
Any issues with this FC? I am thinking about picking one up for my 2" quad.
I have this FC both the old and new version: https://www.banggood.com/Micro-20x20...?rmmds=myorder
First one the LED function didn't work and also got this error intermittently FAILURE_MISSING_ACC: Accelerometer/gyro sensor is missing.
Second one (the new version) the LED works now but still get the FAILURE_MISSING_ACC: Accelerometer/gyro sensor is missing error randomly.
Here is a video of that issue:
Banggood FC Issue (0 min 18 sec)
Very frustrating. All on 3S with a load on the BEC of about 380maH. Might just be the on board BEC that isn't engineered all that well.
Have you had any issues with the board in this thread? Does the LED work, any issues with arming, gyro/accelerometer issues, etc.?
Hope it's working out. I need another option.
Dec 13, 2017, 11:27 AM
How to power this board?
Hello, I just received one of these FCs (Omnibus F3 NANO STM32F303 2-4S Flight Controller 20*20mm 3.7g Built-in 5V 3A BEC OSD).
How do you power the board? Through the B+ and B- pads next to the ESC connector? I will be running my VTX voltage at 5V.
I will also be running this quad on 3S.
Please let me know. Thank you, Chrys Burge
Jan 30, 2018, 08:52 PM
Using this board now on my 2". No problems at all. Not running LED on my build though so I can't comment on that.
Apr 21, 2018, 05:54 AM
This board failed during the build process. QC may not be the best...
I can no longer get it to connect to the Configurator.
New Product Betaflight 3.1 F3 6DOF Mini Flight Controller 20x20mm /w OSD + 5V BEC nitbeat Micro Multirotor Drones 155 Jun 09, 2019 01:22 PM
Discussion Racerstar StarF3S 30A BL_S 4 In 1 ESC 5V BEC w/ F3 Flight Controller AIO OSD BEC Curr scousethief Banggood.com 28 Oct 10, 2018 05:25 PM
Discussion Omnibus F4SD 32K Betaflight_3.2.0 STM32 F405 Flight Controller OSD 5V 3A BEC 30.5X30. scousethief Banggood.com 1 Dec 11, 2017 09:47 AM
New Product Omnibus F4 NANO STM32F405 2-4S Flight Controller 20*20mm (Betaflight 3.2.0) ronniek Multirotor Drone Electronics 0 Sep 15, 2017 07:02 AM
Discussion BF3.1.5 Omnibus F4 V2 Flight Controller STM32 F405 MCU Integrated OSD Built-in 5V BEC scousethief Banggood.com 10 Sep 13, 2017 06:21 PM
