Oct 27, 2017, 09:24 AM
What can I build that performs in small indoor areas like a UMX Vapor Lite HP?
RTF they sell for about $100
I want to build or make kits for my adult children that:
they can fly in small areas indoor or outdoor
are slow, stable, easy to fly RET
gives them a Tx they could use on other models if they like
has all of the build/fly/repair advantages of a foamie
I want to keep the spend at ~$100 or less for everything
Suggestions?
EDIT: here is a link https://www.horizonhobby.com/umx-vap...p-rtf-eflu6800
Oct 27, 2017, 02:42 PM
An itch?. Scratch build.
eflightray's Avatar
Less than $100 to cover how many children ?
Have a look here --
https://www.banggood.com/buy/indoor-...xoCEjgQAvD_BwE
I don't know how long this link will work for, if it fails, search Banggood.com
Oct 27, 2017, 03:19 PM
If it flies - I want one!
Petem's Avatar
If you are scratch building, have a look at the Hangar Rat and its variants - some examples on my blog, right down the bottom.
They work well and any desired size and using balsa and/or foam.
But sadly I have been unable to design or build anything that quite matches the Vapor family for sweet, light and slow.
Cheers,
PeteM
Oct 27, 2017, 03:22 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Suggestions?
Take a look at the scratch built micro indoor forum :
https://www.rcgroups.com/scratchbuil...cro-models-85/
There are several protocols that have 1S powered micro bricks available ( receiver , ESC and two servos .... all built in to a TINY unit about the size of a matchbook ) , the least expensive one is this FlySky protocol brick : https://www.banggood.com/WLtoys-V911...s-p-77849.html There are more expensive bricks available for DSM2/DSMX ( like the Vapor brick ) , and also for Tactic : https://www.towerhobbies.com/cgi-bin...?&I=LXBPYD&P=0
Banggood sells this airframe ( similar to a Vapor ) that will work well with one of the bricks ↑ :
https://www.banggood.com/TY-Model-Bl...rmmds=category
Oct 28, 2017, 08:06 AM
Quads & Planes, cant beat them
sleb's Avatar
I would say the Nutball is the plane you are looking for. It’s been made in size from micro to jumbo. https://www.rcgroups.com/forums/show...-RET-foamy-yet
Oct 28, 2017, 10:58 AM
Round is Fun
Originally Posted by sleb
I would say the Nutball is the plane you are looking for. Itís been made in size from micro to jumbo. https://www.rcgroups.com/forums/show...-RET-foamy-yet
There is a variant of the Nutball called an Underball that can be built for indoors. I am planning to try a 1.3# 6mm EPP construction a try. I will weigh everything I think I will need and then compute how big to make it. Hopefully the motor I have will make enough thrust and it will all work out. I should note that 3mm EPP was used in some of the really small Underballs. I do have some thin XPP. Will try that if need be.
This is the 24" thread: https://www.rcgroups.com/forums/show...e-Underball-24
I'm pretty sure there is a 14" or so thread.
Oct 28, 2017, 12:36 PM
flyin' fool
goldguy's Avatar
You can build this any size using the simple math formula ................ https://www.rcgroups.com/forums/show...t=Smart%20Dart
Same great flight characteristics as the NutBall.
Oct 28, 2017, 01:20 PM
The Dart is my favorite . Since it has no curves , it would be easy to build a micro out of balsa sticks and lightweight plastic film wing/tail-feathers covering .
Oct 28, 2017, 04:24 PM
flyin' fool
goldguy's Avatar
The Dart is based on a rubber powered free flight design, perfect for RC conversion if keep light.
Set it up as a trainer with less control throws and the proper CG, or............ lots of throw and a reward CG and you've got an aerobatic wonder with just rudder and elevator.
Oct 28, 2017, 04:31 PM
flyin' fool
goldguy's Avatar
14 incher with tiny bind n' fly gear .................. https://www.rcgroups.com/forums/show...postcount=5008
Oct 28, 2017, 07:02 PM
Hey, watch this!
Raymond-leflyr's Avatar
I made a 12-inch NutBall out of 3-mm Depron that works a treat (as the Brits would say). Doesn't handle a whole lot of wind but does pretty much everything the "big" ones do.
I know Depron is hard to find and if I had to make a second choice I would go with "stripped" DTF. It would a be a little heavier and therefore not a lively but still something super simple to put together.
Oct 28, 2017, 08:56 PM
flyin' fool
goldguy's Avatar
How about pictures of that 'IC' lamp.
Oct 29, 2017, 03:16 AM
space1
cut two
cut two
Oct 29, 2017, 03:19 AM
space1
cut one
paper plate
Oct 29, 2017, 07:52 AM
Several good ideas here!
I have some reading to do.
To be clear the idea is to scratch build either a complete RTF plane or to scratch build kits for them to assemble on their own.
The budget for everything neeed to fly is the same as the price for the vapor (~$100)
Discussion New UMX Vapor Lite HP mawz Micro Ready-to-Fly 576 Mar 21, 2019 08:45 PM
Discussion Small Building Area and Basic Tools for Building David2011 Balsa Builders 19 Dec 27, 2016 08:47 PM
Discussion What is the best camera with 3.6mm lens under $40 that I can buy in US? CptanPanic FPV Equipment 0 Mar 05, 2016 01:07 PM
Discussion Anyone in the DC area that can help a beginner? Cakebaker Beginner Multirotor Drones 1 Jan 21, 2016 11:49 PM
Discussion Best Micro that can go outside in a small area? GetterDragun Micro Ready-to-Fly 21 Jul 23, 2010 08:14 PM
