Fokker DR1 build thread .09 powered - RC Groups
Oct 26, 2017, 09:56 PM
I'm building a Fokker DR1 triplane which will hopefully be powered by an Enya 09, so I guess it qualifies as 1/2a? Around 30 inch wingspan, for those interested here's my link. Thanks.
Oct 26, 2017, 10:56 PM
Nitro Abuser
Amp Abuser's Avatar
We would all enjoy seeing your build shared here too and look forward to the maiden flight vid.
The forum generally accepts up to 15 two strokes, covers all the array of small engines
within those power levels. Includes the small 4 strokes as they are so limited in power
and within the two stroke limitations of performance / typically some 10 and most 15
size planes can use them.
Oct 27, 2017, 06:41 AM
surfer_kris's Avatar
Keep it lightweight, a 30" tri-plane will be quite large for the little Enya, one 30" wing is usually about right.
What electric power do they recommend? Have you seen any numbers for the total weight on electrics?
Oct 27, 2017, 11:02 AM
The Hobby King site says 650g less electrics and batteries. I am not a fan of Enya .09s.
Oct 27, 2017, 12:23 PM
Ouch, 650g without electrics and battery doesn't sound very promising...
That would instead be a good final weight to aim for with that engine. The largest plane I've flown with the .09 Enya was around 630 grams (if I remember correctly). It flew fine but wasn't very spirited;
Oct 27, 2017, 02:23 PM
Nitro Abuser
Amp Abuser's Avatar
22.2oz with a Enya .09 is ok..
11.7oz with a TD .09 is much better
DART -TD .09 / APC 5.25x6.25E / 143 mph best pass (3 min 26 sec)
Oct 28, 2017, 01:04 AM
Oooh, I'm sure one can build something smaller than that, shouldn't be an issue...
I was showing the plane above as an example of the largest plane that I have flown with an Enya .09 engine. The plane has a 1.1 m (about 43") wingspan and wing area of 23dm^2 (about 356 inch^2) plus a landing gear etc.
I swapped the Enya .09 engine for a Modela (MMVS) Junior 2cc (.12) diesel, and never looked back. It now swings a 9x5 prop with authority and that suits the plane much better than the 7x4-7x5 prop that the Enya liked.
Nov 11, 2017, 07:22 PM
Oh guys I didn't know there were responses in this thread, sorry
The plane is mostly build, just waiting on the fire red ultracote and a 4-40 drill tap set.
Some pics
Nov 12, 2017, 11:49 AM
Well I hope it flies as well as it looks
Nov 12, 2017, 02:20 PM
This one at 32" span was flown with a Johnson 35.
Nov 12, 2017, 05:35 PM
That is cute. I like it
Discussion 770mm Fokker DR1 build pwilk20 Balsa Builders 176 Mar 02, 2018 08:02 AM
Discussion Fokker DR1 wing incidence questionI have recently acquired a Fokker DR1 that was kit Frtdtmrose7 Fuel Warbirds 0 Mar 31, 2017 07:01 PM
Micro Fokker DR1 Build NitroCharged Scratchbuilt Indoor and Micro Models 56 Jul 20, 2009 10:23 AM
Build Log Fokker DR1 from Dymond build thread ORANATOR Scale Kit/Scratch Built 97 Jan 28, 2007 10:24 AM
Question Fokker DR1 - Scale model (Scratch build) 0tigershark Scale Kit/Scratch Built 17 Mar 04, 2004 04:38 PM
