I-Charge V2 and I-Charge Turbine - RC Groups
Oct 25, 2017, 08:37 PM
rickgell's Avatar
New Product
New product out now.
The I-Charge from Advance Radio has been redesigned.
Same size and weight, but faster charging and more efficient.
It can now charge both 2s LiFe, Li-ion and Lipo as well as 3S LiFE for ECUs.
Pretty impressive for a charger that fits in the palm of your hand.
Comes in 3 new types
Pocket Charge:
Lighter, easier to use, charges 2 batteries. Great for mounting in your planes or keeping it in your transmitter case to charge at home or at the field.
I-Charge:
Bright OLED screen gives battery voltage, mAhs charged and charge current, charges 3 batteries, simply plug it into a 12v supply and it will start charging. Weights about the same a servo
I-Charge Turbine:
Designed to charge both 2S and 3S chemistries, perfect field companion for your turbine models, no need to worry about excess wires or bulky charges. Simply plug and go with this micro charger.
Check it out and let us know your thoughts
http://www.boomarc.com/en/battery-chargers
I-Charge V2 (3 min 1 sec)
I-Charge V2 Setup (5 min 21 sec)
Mini-HowTo [WIP] Make Charge Master (v2) works in linux sl1pkn07 Batteries and Chargers 1 Sep 18, 2016 07:18 PM
Discussion Battery charging with imax b6ac v2 Help Joe2004 Batteries and Chargers 3 Jul 22, 2016 04:55 AM
Discussion Duracell 1.2v 2400mah NiMh x8 charging via HK-T6A V2 via charge port Question LemonC Batteries and Chargers 5 Oct 03, 2014 05:34 PM
Discussion NEW! VERTIGO Formost 150 V2.0 Fiberglass JET For EDF or Turbine Power! wingspan100 Electric Ducted Fan Jet Talk 12 Oct 15, 2009 12:36 AM
Discussion Wind turbine to charge Nicads mr. fix-it Batteries and Chargers 8 Jul 09, 2008 07:25 AM
