Eagle eye tracker set up questions - RC Groups
Oct 25, 2017, 03:48 PM
So how are you suppose to set up the antenna tracker for the eagle eye?
I tried to use the vector software but Eagle eye doesn't seem to do anything when I click calibrate tracker.
I also tried to use the Data Recorder software, but it kept telling me that I need to upgrade the firmware for ealge eye to 1.26, when it's already at 1.26 or 1.31. And it just close and never reopens again.
I also connected the Vector to my pc, thinking that they need to talk to each other, but no, still the same...
There's also no up to date /many video on how to set it up, this is really frustrating...
Oct 26, 2017, 01:21 AM
There are 2 ways to calibrate the EE.
1st way without PC connection: Power up both your Vector (with connected VTX) and the EE (with connected VRX). Itīs important that the telemetrie LED is flashing. Now you can calibrate the EE in the Vectors OSD menu.
2nd way with PC Connection: Connect your Vectro to your PC open the Vector Software and power up the Vector (with connected VTX) and the EE (with connected VRX). Telemetrie LED needs to flash too. Use the Software to calibrate the EE.
Oct 26, 2017, 05:15 PM
Thanks for the response! But I tried both way and the telemetry light wasn’t flashing.
Oct 27, 2017, 07:37 AM
Did you connect a camera? As far as I know you need to connect a camera to. Otherwise it wonīt work. The telemetrie information for the EE is hidden in the first rows of the video image that you canīt see on the screen. The Vector needs a connected cam to transmit this information.
Oct 27, 2017, 07:39 AM
Do you have a clear Image if you use the video-out at the EE?
Oct 27, 2017, 11:04 PM
So everything worked when I connected the camera! Thank you very much!!!! But they should really put these details on the manual....
Jan 31, 2018, 10:12 AM
Is there a way to make the EE work without using a vector? I am using a Pixhawk 2.1 FC along with TBS CrossFire and TBS vTx. Mission Planner is receiving telemitry through the crossfire, so I'm wondering if the EE could get the GPS info from that to make the tracking function work. Or is there a way to get the GPS info to come through the smartaudio from the vtx?
Thanks for your help!
** What I really want to work is the tracking function, I am recieving video.
Feb 01, 2018, 09:28 AM
JohnET's Avatar
Hello,
No, as far as I know the Pixhawk has no way to replicate the telemetry requirement for the Eagle Eyes tracking feature. The Vector integrates the telemetry into the video stream.
Regards, John
Feb 01, 2018, 01:21 PM
Originally Posted by JohnET
Hello,
Regards, John
Ok, other options? What can I install that would transmit only the nessary info for the tracker? Is all it needs is gps data transmitted from an eagle tree device through audio/ video feed? I would be willing to do that and integrate it with the feed already being sent....possible?
Feb 01, 2018, 01:31 PM
JohnET's Avatar
You would need either a Vector or MicroVector installed in the aircraft with a GPS, camera (it must have an active video signal) and video transmitter and send the video to a video receiver connected to the Eagle Eyes. In short, you will be duplicating your whole flight controller and FPV system. I suggest either replacing your pixhawk with a Vector/MicroVector or find a tracker designed to work with the pixhawk. These are 2 competently different and incompatible systems.
Regards, John
Feb 01, 2018, 03:08 PM
Ok, this makes sense. Could I still use the EE for antenna diversity switching and come up with a different driver for the tracking?
Feb 02, 2018, 08:38 AM
JohnET's Avatar
Yes, the Eagle Eyes diversity does not the video signals to come from a Vector.
Regards, John
Feb 02, 2018, 09:00 AM
good deal. Do I need to setup the diversity function? I had it powered up last night and just to see if it worked, I disconnected the #1 receiver and I lost video. It did not switch to the other receiver.
***Never mind, figured it out***
Feb 22, 2018, 04:20 PM
Hello
Hi I've updated an EE and with the vector software to 1.31. Now I want to continue to install but it seem like not get contact via the USB connection. Anything else ok (cam vector etc) Have maybe played too much with the buttons instead of using the vector software. Can I reset the vector?
Feb 23, 2018, 07:45 AM
JohnET's Avatar
Hello,
Using the buttons or resetting the Vector will have nothing to do with the Eagle Eyes not connecting with the computer. I suggest trying different usb cables, different usb ports and making sure you have power management disabled in Windows.
There is a known issue with Windows 8.1 and higher and usb devices, not just our products. It is an issue with the power management that Windows 8.1 and higher uses.
Please refer to the following Microsoft Knowledge Base article regarding this issue:
http://support.microsoft.com/kb/2900614
We hope that Microsoft will release a patch that will prevent this feature from being the default configuration for USB devices.
If you are unable to get it working, please open a support ticket.
Regards, John
Discussion New Eagle Eyes antenna tracker Killerbean Eagle Tree Systems 3 Jul 02, 2016 08:28 AM
Help! Eagle eyes tracker problem. biget Eagle Tree Systems 2 Jun 27, 2016 12:58 PM
Discussion Fine tuning Eagle eyes tracker....lagging behind a bit...??? SKT Eagle Tree Systems 1 Oct 30, 2015 05:30 AM
Discussion Eagle Eyes Tracker setup and multiple aircraft? SKT Eagle Tree Systems 13 Oct 29, 2015 10:41 PM
Discussion Eagle eye as sun tracker Hugeone Eagle Tree Systems 1 Nov 03, 2010 12:12 AM
