Thin paper covered foam sheet? - RC Groups
Oct 25, 2017, 03:43 AM
Idea
Any source for 1/32" or 1/16"thk paper covered foam board? That would be .75mm and thk.
If not, I'm thinking I can make my own sheets cut from 2lb styrofoam, as it's stiffer than 1/lb and cuts cleaner with a hot wire, Attaching straw colored tissue presents some problems but not insurmountable.
I want to cut ribs and use as wide wing sheeting , etc. A direct substitute for balsa.
Oct 27, 2017, 04:04 PM
Hope to get out of life alive
kenh3497's Avatar
A long time ago I sheeted a foam core wing with "tag board". Maybe you could produce your own sheets using tag board and foam core. Use epoxy or Polyurethane glue to bond the parts together.
Oh, the wing worked just fine. It was plenty strong, maybe a tad heavy but my selection of tag board was pretty limited then.
Ken
Oct 28, 2017, 03:17 AM
supreme being of leisure
ZAGNUT's Avatar
i've made my own foamboard using 60g kraft paper. much lighter and stiffer than the arts and crafts stuff. basic idea is that the paper goes on wet and then shrinks to create a drum tight skin. newsprint can be used for a lighter version. same idea and process as paper covered foam core wings.
Discussion How come commercial foam sheets are so thin? Iboxx83 Foamies (Scratchbuilt) 2 Jun 04, 2010 03:46 PM
EPP Foam in thin sheets ..? sylair Foamies (Kits) 0 Aug 01, 2005 08:35 PM
Question Were can i buy thin sheets of EPP foam? tripxrcer 3D Flying 2 Jan 08, 2004 05:47 PM
Source for foam core / paper skinned foam sheets Kevin Murray Electric Plane Talk 6 Sep 08, 2001 05:07 PM
