F18 OS91 balsa build - RC Groups
Oct 23, 2017, 02:35 PM
dpot's Avatar
Build Log
OK if you are going to laser cut go to //F18layout 0offset//shutdown layer //EDF4.5//
now top layout is cut from 5.5mm / 6mm x 1200mm x 300mm birch ply one former is important F5 this former supports the wings so get the gran of the ply running along the wing brace to give it as much strength as you can it has to be good ply and the spars that run top and bottom must be from softwood.
//F18layout 0offset// shutdown layer //EDF4.5//
next 2 layout are from 3mm x 1200mm x 300mm light ply on the second layout you have the wing ribs you need to cut two that's is all the ribs and formers up to and including H3BOS91 on the image in purple you have to have two of each all the other former just one on that layout.
3 layout 3mm x 1200mm x 300mm light ply
Oct 23, 2017, 07:18 PM
AndyKunz's Avatar
My laser cut F-18A is a work in progress. Thread is in Balsa Builders if interested.
Andy
Oct 24, 2017, 04:31 AM
dpot's Avatar
if anyone is intrested planes and all the cad files 28MB to cut and build this F18 hornet ducted fan os91 or EDF with retracts just clip together 3d images and Fig drawings instructions all for 150 euro cut as many as you need
this one is all finished she had her first flight in 1995 and then up dated in 2000 for 3mm light ply easy build for OS91 ramtek or 75mm EDF on 10s that's 2 / 5s 4000 the original build is on the cnc http://www.cnczone.com/forums/parts-...ml#post2089278 it flys on railes
i am now working on a foam version of it as the EM 10 Bielik///textron scorpion
Oct 27, 2017, 01:44 PM
dpot's Avatar
canopy in the video are 3 ways to make plug for vac forming first i routed out a hard wood plug then a foam block and sanded it to shape on the model this will give you one good pull after that it gos out of shape but if you use the first pull and mix up sum plaster of paris i use dry lining adhesive works great or you can 3D print it for a plug
i use rhino can for router and stl and Simplify3D for printing and just your eye for sanding
in the cd cut files you have there are dwg /stl / dxf / 3dm files the stl will 3d print dxf to make g code and a g code for match3 for your cnc router
F18 canipy (2 min 10 sec)
Oct 29, 2017, 04:36 AM
dpot's Avatar
It is important to build the wing first as fig9 using F4 as a gig for the wing ribs then build fuz Fig3
Oct 31, 2017, 12:58 PM
Hi, were at this stage right now.
We went to a CNC cutter and they told us that the .tap files you sent couldn't be used because they're set up for a specific machine and could end up breaking their cutter. Could you please send me the canopy, cowl plug and elevator files in AutoCAD 3D format so they can be cut and/or procesed for the CNC machine? Thanks
Oct 31, 2017, 02:34 PM
dpot's Avatar
yes the g code is setup for my router and it depends if you have the o,o,o set to the bed or the top of box stock.
in the zip you should have a extension format .STL this is a stander 3d format i have attached new stl files in zip for you
Oct 31, 2017, 03:11 PM
dpot's Avatar
make sour that the wing spars in red on image are out of softwood and fitted as image this give good support to wings the trailing edge and rear spar goes through as fare as you can to add strength to wing you have to add packers off the top of the uc plat to under the spares
Dec 12, 2017, 11:18 PM
Hi..dpot...Would you teach me step by step how to create f18 design like you uploaded above using Rhino?with Video will be great, and I am very grateful if you wish
Dec 15, 2017, 12:24 AM
dpot's Avatar
the F18 her was draw with autocad 2007 from a 3 vieu using the old drafting way of a 45 degree line to plot the formers that comes from the days of pencil and paper T square / square and set square /
Dec 20, 2017, 09:51 AM
Bruferrit's Avatar
man I remember those days, drafting with a pencil.
Dec 21, 2017, 12:34 AM
dpot's Avatar
yes scraping out ink lines with molding blades and the smell of the diyliner that printed the drawings good days
Apr 10, 2018, 09:54 AM
what coad
Apr 10, 2018, 01:43 PM
dpot's Avatar
post 1 post 3 post 4
Build Log Wanderer scratch build - balsa build log zarqeon Balsa Builders 111 Apr 08, 2018 06:20 PM
Question BALSA BUILDERS! Best First Balsa Kit Build? thefishhunter Thermal 13 Aug 28, 2017 08:01 AM
Build Log SIG Wonder Build - First Balsa Build Joey620 Balsa Builders 12 Aug 04, 2017 03:02 AM
Build Log Lx F18 Super Hornet stock ARF build. helifann Foamy EDFs 16 Mar 03, 2017 04:11 PM
Build Log F18 light ply balsa for EDF dpot Electric Ducted Fan Jet Talk 61 Sep 10, 2010 12:17 PM
