Oct 22, 2017, 02:20 PM
skylane42's Avatar
Question
Iron on fabric covering?
what are you guys using for a iron on fabric look covering.. looking to do a Bud Nosen Citabria..
Oct 22, 2017, 02:50 PM
Mumbling in the corner.
flyboy2610's Avatar
My plan is to use Solartex from Balsa USA.
I'm going to do the PT60 with it to learn to work with it, and then do the Elder 40 with it. I haven't actually used it yet, though.
http://shop.balsausa.com/category_s/1322.htm
Oct 22, 2017, 05:28 PM
Solartex or Ceconite work well. If Ceconite you must provide the adhesive and paint.
Oct 23, 2017, 06:12 AM
skylane42's Avatar
What Adhesive would you use with the Ceconite?
Oct 23, 2017, 06:49 AM
ARFs Are Me
TomCrump's Avatar
For my models, I choose Natural Solartex.
It requires no filling of the weave, nor does it require primer.
Most paints can be used over it. I've used automotive paints, like PPG and NASON, but my preference is Rustoleum.
Solartex has an adhesive, but I enhance the adhesion by spraying the air frame with Aqua Net hair spray.
The pre-colored Solartex is fuel proof, but I don't think you would be happy with it, without sealing it with a clear coat. The unsealed product tends to attract dirt.
I would suggest that your Citabria is a perfect candidate for Natural Solartex and a Rustoleum paint job.
Here's a pic of my recently completed Cub, covered in that manner and painted with Rustoleum aerosol cans.
Oct 23, 2017, 08:44 AM
skylane42's Avatar
NIce !
Oct 23, 2017, 12:56 PM
I use uncertified light aircraft fabric for my rag wing planes. Put it down with Randolph dope then finish/paint with more dope. You can buy it relatively inexpensively at Aircraft Spruce and Specialty.
carl
Oct 23, 2017, 02:35 PM
Nitrate dope is probably best. You can get it at most private airports or from several hobby sources, Aircraft Spruce being one of them as well as a source for Ceconite. One of the nice things about Ceconite is that you can get it in very long rolls, I do not know the maximum but that sure helps on large planes. It is also a full meter wide, not the 36 inch on so many of the iron on films.
Oct 24, 2017, 10:52 AM
San Antonio TX.
sensei's Avatar
My vote is also for Ceconite, along with poly dope, poly spray and poly tone, had real good results over the years both in covering models and full scale. Been buying from Aircraft Spruce for nearly 40 years now, great folks to work with.
Bob
Nov 02, 2017, 08:55 PM
similar to above
I really love Stits Lite which is applied with Poly-tak, the Poly Brush to fill weave and Poly spray for base/UV (on full scale). Poly Tone colors/paint then added. Poly Tone paints have great pigment, spray wonderful and majority material evaporates in cure. Just like the scales. More work but if looking for scale look, its great
it shrinks dang near any curve you throw at it, does beautiful fillets in cloth. will never sag. you can add pin tape and simulated stitching.
be glad to share covering pics of a recent Robinhood 99 that I completed in the stits/poly sytem
Nov 03, 2017, 04:55 AM
San Antonio TX.
sensei's Avatar
Originally Posted by RagwingFan
similar to above
Sure, l would love to see them.
Bob
Nov 03, 2017, 11:14 AM
San Antonio TX.
sensei's Avatar
Very, very nice! The only way to go in my opinion...
Bob
Nov 03, 2017, 12:33 PM
Thanks Bob
I have done majority of coverings over the years. Monokote, Century 21 pre-painted fabrics, old Coverite Supershrink (loved that stuff) and then tried Stits lite on my Stinson. Hooked immediately. I still need to try Solartex and then paint. Apparently great stuff as well.
Dec 04, 2017, 07:25 AM
I had some experience applying Ceconite and dope over a plane. I helped built a Fischer Flying Products FP101 ultra light. It was October and we had the garage doors closed with a small heater going and a 12 pack of Miller.
Had no idea what was happening until too late...cruising at 10000 without realizing it. we were laughing and joking....having a real good time of it.
Beer and dope don't mix well unless you like having happy hour.
Discussion Update-White Solarfilm Iron-on Covering E-Challenged Scale Kit/Scratch Built 0 Sep 24, 2017 04:42 PM
Help! ESM Models - Iron ON Painted Covering Wrinkles: electriceddie Fuel Warbirds 1 Jan 27, 2017 09:31 AM
Discussion ESM Models - Iron ON Painted Covering Wrinkles: electriceddie Scale ARF/RTF 0 Jan 21, 2017 08:05 PM
Discussion Light weight iron-on covering for small electrics/free flight ? mike912e Free Flight 13 Sep 25, 2016 06:20 PM
Iron on heat shrink iron on covering mr.Q Scale Fuel Planes 2 May 14, 2005 08:42 PM
