Epoxy - RC Groups
Oct 21, 2017, 11:18 AM
Epoxy
Recently had issue with epoxy not curing. Any suggestions? Been building for 50+ years so not looking for answers such as not mixed properly Thanks in advance.
Oct 21, 2017, 01:04 PM
Dinosaur
Twodor's Avatar
Too cold in your shop or...maybe you did what I'll admit to doing a couple of times over the years. Mix your epoxy using part 'A' twice?
Tom
Oct 21, 2017, 02:06 PM
Maybe it was too coll. Thanks!
Tom
Oct 21, 2017, 02:59 PM
AMA 46133
I also think it is too cold in your workshop. I think if you are anywhere below 60F it may not cure, at least for a long time. How old is the epoxy? Never mind, I actually have over 30 year old epoxy that cured fine. Still using them.
Oct 22, 2017, 08:43 AM
ARFs Are Me
TomCrump's Avatar
When I worked in an auto plant, we had a saying about questionable parts. "When in doubt, toss it out" I think that it applies to your situation.
Oct 23, 2017, 04:38 PM
EXF3BMAN's Avatar
There are only 3 reasons why epoxy may not fully cure.
1. Improper ratios
2. Not mixed well enough
3. Too cold.
If the initial cure was done in too cold of an environment, it will eventually set up. A heat gun a few times a day will greatly speed that up. If with the application of heat over a couple days does not make a difference then as much as you don't want to hear it, it has been mixed in the wrong ratio or not mixed well enough.
Oct 23, 2017, 05:11 PM
San Antonio TX.
sensei's Avatar
1. Improper ratios
3. Too cold.
Who likes epoxy anyway.
Bob
Oct 23, 2017, 07:50 PM
EXF3BMAN's Avatar
LOL Bob, in the last 7 days I have been part of a process that has dispensed over 200 gallons of mixed epoxy resin. I should hate working with the stuff but just ordered enough to glass this fuselage and produce a set of molds from it.
Oct 23, 2017, 10:14 PM
San Antonio TX.
sensei's Avatar
That thing looks awesome buddy.
Bob
Oct 23, 2017, 10:25 PM
tailskid2's Avatar
Try putting the part(s) in your car and with the windows up, let it sit in the sunshine for a day or two. Had to do that a couple of times when I lived in Fort Wayne, Indiana.
Latest blog entry: Next!
Oct 23, 2017, 10:37 PM
EXF3BMAN's Avatar
Bob
Thanks Bob, it's something I have been designing in my head for a while and finally decided to make it a reality.
EXF3BMAN's Avatar
A great way to expose epoxy to an elevated temp.
Oct 31, 2017, 02:06 PM
What sort of epoxy resin was it (brand and version)? Laminating or adhesive? Ive had trouble with some resins where i needed to stir up the resin because it was old and started to separate before mixing in the hardner. I also use heating blankets to control the cure rate more easily. Ive also had trouble when Ive mixed small batches but that's been more the case with tooling resin.
Oct 31, 2017, 08:51 PM
Any chance the epoxy is great planes brand? I had the same issue about a year-ish ago and learned a bad batch got out. I tossed it and switched to Devcon and no problems since.
Nov 01, 2017, 03:35 AM
I buy in larger quanties and have no problem as long as you weigh it, i use a 5 to 1 mix, so 20 gram, epoxy 4 gram hardener etc. and keep it warm when you are using it.
Discussion best epoxy for joining very old epoxy fuse halfs Rudy F Composites Fabrication 10 Dec 10, 2016 10:37 PM
Question Epoxy to Epoxy joint? lwndart Beginner Training Area (Aircraft-Electric) 3 Mar 07, 2006 08:21 AM
Rant NHP Epoxy 30, the Epoxy From Hell PGR Slope 20 Jun 21, 2005 01:39 AM
Epoxy + Epoxy tenover Electric Plane Talk 2 Aug 28, 2002 09:49 PM
