Flysky FS2A 4CH AFHDS 2A Mini Compatible Receiver PWM Output for Flysky i6 i6X i6S - RC Groups
Oct 19, 2017, 07:21 PM
Quad Erat Demonstrandum
scousethief's Avatar
https://www.banggood.com/Flysky-FS2A-4CH-AFHDS-2A-Mini-Compatible-Receiver-PWM-Output-for-Flysky-i6-i6X-i6S-p-1214269.html
Product Detail
Description:
Item name: Flysky FS2A 4CH Receiver
Channels: 4CH
Output signal: PWM
Frequency range: 2.408-2.475GHZ
Band width: 135
Receiver sensitivity: -92DBM
2.4G mode: AFHDS 2A
Failfe: Yes
Supply voltage: 3.3-10V
Distance: 400+ meters
Working current: 20MA
Dimensions: 11 * 25MM
Weight: 0.9 grams
Support: FS-I6, FS-I6X, FS-I6S, FS-TM8, FS-TM10, FS-I10 and other AFHDS 2A protocol transmitter
Bind:
1. Press and hold the key on the receiver and connect the power to the receiver. The blue light on the receiver flashing, get into bindind mode.
2, Set the transmitter into bind mode (confirmed AFHDS 2A protocol). After getting into bind mode, the receiver light changes from flashing to slow flash.
3, Transmitter get out of bind mode, then the receiver blue light becomes bright. Indicates that the signal receive is successful.
Failsafe settings:
The receiver can normally receive the transmitter signal, push the rocker to the the failsafe set, long press the receiver bind button, the blue light flashes quickly several times and then always bright , failsafe settings is successful.
Pacakge Included:
1X Flysky FS2A 4CH AFHDS 2A Mini Compatible Receiver
Oct 23, 2017, 01:25 PM
FYI, the link is broken. I like your posts!
Oct 23, 2017, 06:22 PM
Thank you Lanza , i have fixed the link and i have one of these coming to me so i will post back at how well they work.
Scouse
Apr 09, 2018, 10:04 AM
So little info about this one. I think it will be suitable for 3ch mini plane.
New Product [Updated]Flysky FS-i6X 2.4GHz 10CH AFHDS 2A RC Transmitter --FREE TEST BG Tobey Radios 392 Mar 30, 2018 05:43 AM
New Product (Updating)New Version Flysky FS-i6S 2.4G 10CH AFHDS 2A Transmitter With FS-iA10B BG Well Mini Multirotor Drones 190 Feb 05, 2018 07:23 AM
Discussion The smallest radio receiver compatible with FlySky i6 AFHDS 2A udoor Mini Multirotor Drones 24 Sep 17, 2017 01:19 AM
New Product Flysky X6B 2.4G 6CH i-BUS PPM PWM Receiver for AFHDS i10 i6s i6 i6x i4x Transmitter lmpuIse Radios 6 Aug 30, 2017 12:07 PM
New Product Flysky FS-i6X 10CH 2.4GHz AFHDS 2A RC Transmitter + RX nitbeat Radios 0 Nov 01, 2016 12:02 PM
